20 Most Recent
Soundstorm SDVD-100 Car DVD Player Questions & Answers
Dvd is stuck will not
>>> Please leave feedback so I can continue helping You & Others
LOOK FOR A SMALL HOLE IN THE FRONT TO PUSH A PAPERCLIP INTO, BUT TURN THE UNIT OFF FIRST. Try pulling the car fuse out, will have stereo/radio written on fusecase.
Thanks,
Adam.
Forgot parental pass code.
With some decks you can get in using either an all 0 code or an all 9 code entered as the parental passcode.. have you disconnected it from the power supply and let it sit for a bit to see if you can clear the memory?
Put a childs dvd in asking for parental code?
There is a factory preset parental code you need to enter (unless that default code was changed). That factory code is in your user manual. In order the enter the codem, you will need the remote (number pad). The remote can be ordered through Soundstorm for $35.00 and you can download the manual from their knowledge base, just search "SDVD-100". Once you have both, just use the number pad on the remote to enter the factory parental code and the system will unlock.
Soundstorm car dvd player
This is from the soundstorm website:
If your DVD player shows a "Parental Code" on the screen. Here is the factory default code. It is 3308.
Once you have this code, you can go into the settings and change the level to whichever level you like.
Here is a break down of the levels:
Level 1 = G Rated
Level 3 = PG Rated
Level 4 = PG 13 Rated
Level 6 = PG-R Rated
Level 7 = NC-17
Level 8 = Adult
Level 0 = No Parental
Modelo sd745t radio para coche tengo problemas que el panel fron
Es posible que alguno de los switches este defectuoso y se a de haber quedado oprimido y eso causa que se bloquen todos las funciones.Por lo regular,cuando un switch esta defectoso no se siente el click al oprimirlo.
Espero que esta informacion te ayude en algo.
Gracias y suerte
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
