20 Most Recent Mach Speed (MSNV-939) Motherboard Questions & Answers
System dead
Hi Fr.David You mention '..info on BIOS..' Is your BIOS (or anything) displaying on the screen? If screen is also dead, then your PSU 5V (red) section is suspect. As the fans are fanning then 12V DC (yellow) is still OK. To check your PSU, unplug & disconnect all power connector cables (note where they go, esp the M/Board supply). Some PSU's have a green 'signal good' wire which to test must be grounded with a paper-clip etc to black. This tells the Power Supply Unit to start up. Black is common negative, Yellow 12V positive, Red 5V positive. I'm positive. I hope your test results are not too negative. ;) Hope this helps. Clive.
10/28/2017 11:55:46 PM • Mach Speed... • Answered on Oct 28, 2017
2answers
Will msnv-939 motherboard and realtek ac 97 work on widows 7
check with the manufacturer
3/22/2014 2:34:34 PM • Mach Speed... • Answered on Mar 22, 2014
Jumper bios 3
to enable lan you will have to go through the bios when you start tape f8 or f11 or esc to get into your system setting
10/24/2013 12:38:16 AM • Mach Speed... • Answered on Oct 24, 2013
5answers
No boot on start up all fans start but no video
I had same problem!
I figured there was something wrong with my memory because that is what the manual says the constant beeps mean.
I bought a new PNY memory stick 1 gb DDR and got the same beeps when i put it in.
So being totally disappointed I tried putting the Stick in the #3 DIMM. I booted up and IT WORKED!
I have not called tech support or tried both 1 & 3 DIMM together but I will try after I set up the rest of my computer.
3/4/2013 6:00:29 PM • Mach Speed... • Answered on Mar 04, 2013
2answers
Cpu fan failure message on startup, press F1 to
Get a new power supply as soon as you can ...cheap
12/5/2012 8:12:15 AM • Mach Speed... • Answered on Dec 05, 2012
Msnv-939 memory
do you have max 1gb stick installed.. its max 4 gb @ max 1 gb per slot?
12/14/2011 9:41:39 PM • Mach Speed... • Answered on Dec 14, 2011
0answers
2answers
I turn on the computer
It could be overheating. After it shuts down, restart it, and enter BIOS SETUP, and look for a "PC Health" or "Status" entry on the menu. If you're lucky, it will report the current CPU temperature, and the speed of the fans, and the settable temperature at which it will shut itself down.
Check the capacitors on the motherboard -- any capacitor with a "dome" on top, instead of perfectly-flat, is a leaking capacitor that is intermittently failing.
11/8/2011 9:50:29 PM • Mach Speed... • Answered on Nov 08, 2011
My DVD burner disappeared from
Go to device manager and uninstall the offending hardware. I had the same problem running Windows 2000 with dual DVD burners. They both stopped working and I tried unplugging them and rebooting-no luck. Tried fooling in the BIOS - no luck. Tried reinstalling the drivers - no luck.The uninstall worked! After a reboot, Windows found the drives and installed them
11/8/2011 9:47:24 PM • Mach Speed... • Answered on Nov 08, 2011
Will it run 64 bit os?
Visit http://tiger.tv/more_info/?288 for more on this great motherboard. Mach Speed's new MSNV-939 motherboard
11/5/2011 9:41:10 AM • Mach Speed... • Answered on Nov 05, 2011
What kind of battery does the mach speed msnv-939
motherboards take the cr2032 lithium battery
4/9/2011 3:46:36 PM • Mach Speed... • Answered on Apr 09, 2011
2answers
My motherboard has four 1GB DDR modules installed,
Hello there,
Some Motherboards can only use two Ram modules, we would need the make and model of the Motherboard and the make and model of the Ram .
are the Ram models a kit of Two or did you buy all four at the same time in one Kit here are a few questions to get us going .
1/27/2011 2:32:14 AM • Mach Speed... • Answered on Jan 27, 2011
My screen is blank n keeps asking me to restart
Use this CD
LINK
11/28/2010 6:13:00 AM • Mach Speed... • Answered on Nov 28, 2010
The boot drive blue screened.
Fist clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
then test your power supply unit PSU
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive one bad lead will cause a computer to shut down
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/f which will automatically fix any corrupt files on your hard drive
hope this helps good luck
you have to keep?a computer very clean & free of dust ?and? give it regular?maintanance
good luck with this
9/9/2010 3:10:49 AM • Mach Speed... • Answered on Sep 09, 2010
Nstdr is missing
You need to reinstall Windows if you took it out of a different system. Windows is built according to your hardware when it is installed, you can't just drop the HDD into another, completely different, system and expect it to work.
Back up any data you want off that drive and format and reinstall windows and any other programs you want. That is the only way to make it work in your situation, sorry...
12/13/2009 8:49:17 PM • Mach Speed... • Answered on Dec 13, 2009
Cannot find my original CD for the
Go to driverguide.com They have tons of drivers.
9/30/2009 5:05:46 AM • Mach Speed... • Answered on Sep 30, 2009
Motherboard problems
hi im josh in cebu phils. since that is all fan that works.there is no current that goes or pass on your hardware. all you have to do is check the powersupply connection to the motherboard.both 16 pins and the 4 pins 12 volts. if still change your motherboard. good luck
2/21/2009 2:11:27 AM • Mach Speed... • Answered on Feb 21, 2009
Mach Speed (MSNV-939) Motherboard Logo
34 questions posted
Top Mach Speed Computers & Internet Experts
MegaByteMe
MegaByteMe
Vinho Xie
Vinho Xie
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Mach Speed Computers & Internet
Most Popular Question
consustently get disk boot failure
  • Computers & Internet
