20 Most Recent
Lexmark Polaroid P310 Photo Printer Questions & Answers
Im trying to print my pictures from my Android cell phone via USB cable, any help would be appreciated!!
Well, a couple things here. First to try is to connect the phone to one end and then the USB side to your printer directly. Your device should be recognized or prompted to install software. If it prompts you to install software I would hook the USB up to your computer and install the device there. Then it will import your photos to your computer and you can print it from there. You should also have a Blue Tooth feather that will allow you to connect wirelessly with your printer (if your printer has this feature)
Instructions manual for Lexmark Polaroid p310 photo printer
http://www.lexmark.com/publications/pdfs/310/eng/ug.pdf
This link will take you to a manual for the Lexmark 310/315 series. It doesn't show the P310 Photo Printer exactly but the information can be helpful. On Page 15 is tells you how to get the printer to print exactly the picture you want. You need to refer to the instructions that came with your camera for PictBridge connection and usage. It helped me.
Theres nothing in my printer to put the ink into
It could be that the cartridge carrier just did not move to the loading position.
If you're having trouble with the cartridge carrier not moving
automatically to its loading position (to install/replace cartridges) even when
the printer is on and the cover is open, please follow the steps below:
- Unplug the printer from the
power source.
- With the printer cover open,
hold the solid white strip that connects from the carrier assembly to the
ink cartridge carrier and gently slide the carrier to the center of the
printer.
- Open the latch and remove the
used cartridges.
- Load the new cartridges. Close
the latch and then the printer cover.
- Re-plug the printer to the
power source.
- After going through the startup
process, try to print a document to verify that the cartridges are working
and installed properly.
CAN I PRINT PICTURE FROM MY CELL PHONE WITH THE LEXMARK PRINTER
Lexmark introduces the LexPrint Mobile Print Applictation so you can print from Apple devices such as iPad, iPhone and iPod touch using any Lexmark printer connected to the same wireless network. To learn more about this software, please visit the Lexmark website at http://bit.ly/aLH40U).Also, Lexmark recently released the Lexmark Mobile Printing Application for use with Android devices, however, the application is supported only on most laser products and the very latest inkjets that are coming out for 2011(the Lexmark Pro715 and the Pro915 are the only models announced at this point.).For other cellphone models that does not support Apple IOS or Android, these will not be applicable to your printer.
Trying to print from lexmark
Try replacing your print cartridges. The other color rather than RED in the cartridge are empty or the nozzles are jam.
Is it only for use
Yes-This printer cannot connect to a computer. You need to connect it directly to the camera using the USB cable provided with the Camera
Dont know what number ink cartridges I need
For the Lexmark Polaroid P310 Photo Printer you will need cartridge number 33 and 35.
These are both available on the Lexmark website for ordering and purchasing online or you may want to visit a nearby store for the same.
This will resolve the issue you are facing.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will look forward to your feedback and positive rating.
