20 Most Recent
Philips SA1100 MP3 Player Questions & Answers
My Mp3 Player Only Has 64 Songs Downloaded
check the capacity...it depends on the size of the songs you downloaded...you can check the capacity of your mp3 player by pressing right click and check the properties of your mp3 player
Can delete stuff of it
Hello.
You need to plug it to the computer, and go to the folder where there
is voice recordings, click on it then you can delete/copy the files
there.
How can i copy sounds onto it
what do u mean by sounds as in music if thats the case then u can use the windows media player to copy stuff to it or u can maunally do it urself by opening up the device on the computer icon the clikc on it twice to find indidvual folder to drag ur music file and drop it on the folder to copy*
Problem
The songs are in the wrong format - this player does not work with iTunes, and it doesn't support DRM-encrypted WMA's. Convert all of your files to mp3 format, and you won't have a problem.
Seperate Playlists
Use Windows Media Player to create the playlist, and then transfer them to the player by dragging the entire folder to the sync window, instead of dragging all of the files within the playlist to the window.
Playlist Trouble
Delete the track number from the ID3 tag to get around this problem. Make sure the GoGear is not set to shuffle - make sure the shuffle is OFF.
SA1100
This is usually caused by corrupt firmware on the player.
Install the Firmware Manager software from the product CD.
Open Firmware Manager and select the repair option.
Player problem connect to pc
Sa4111
I am not familliar with the SA4111, but it seems to be identical to the SA11XX series.
With the SA11XX freezing was caused by protected tracks or corrupt firmware.
The procedure for the SA11XX series is as follows:
Removing the battery should reset the player.
Check that your files are not protected (DRM). If they are, format the player and load a non-protected test track, and try again.
If the player still freezes then install and run the Firmware Manager from the product CD.
Select the repair option and follow the on-screen prompts.
SA4111 1GB gogear
These players do not need Synching.
Try dragging and dropping your tracks on to the player with Windows Explorer or My Computer.
My mp3 doesnt play music properly
This is caused by the ground connection from the earphone socket not making contact with the main PCB.
This can be repaired by anyone competent with a soldering iron.
The four contacts on the earphone socket need to be re-soldered.
Hello
