20 Most Recent
APC Silcon UPS System Questions & Answers
My silcon 40kw was not run on batries battries are
please clarify your problem. is the ups on? does it report any alarm? to see this alarms press * , then scroll down using the keypad button that has an arrow in it. if there is no battery weak alarm, press the enter key. does the display read 'normal operation' and does is show load percentage? if so press # the scroll through using arrow keys untill you get 'battery capacity test' , press c then # , this should start a battery capacity test, press battery voltage key. if the batteries are okey the voltages should read 400 then they continue to drop gradually. to revert to normal operation press # then c then # this should bring back the ups to normal operation
Problem (Stand by) Silcon 40kw 400v UPS (SL40KHB2)
Your English is OK, I can understand it! I can't say for sure but I believe that some UPS units don't come on unless they batteries are charged and in good condition. Try to locate the cells/batteries and check each one individually with a volt meter. The voltages should be almost the same on all batteries (usually 12 volts).
Silcon 60KVA fulty
1> UPS go to bypass agan an agan ?1ans> check all battery .2>ups in dead condiction ?2ans > check power supplycontact . 03432475834
I have a APC Silcon
I have apc silcon 20kva ups my ups is working fine but display scree the ups front door machine language what i m doing.
regard
Silcon DP360, 3-phase 60kva, 400v,
#1. You should call APC Technical Support. It's free, and they will help you. You should get voltage even without a load on the unit.
#2. There is a Tripple-Slot unit for this device. It's specific for the Silcon based units. Read the manual, and there is a PN that you need for it. If it doesn't say SILCON, then it won't work. (I tried).
Paul
Data Centers Canada
www.datacenterscanada.com
