20 Most Recent Gigabyte GA-8S661FXM-775 (4719331838096) Motherboard Questions & Answers
2answers
Intel E5500 processor compatible?
Here is a compatibility list: Compatibility list Gigabyte GA-8s661fxm The E4500 which is very similar, just slower clock speed is supported. I cant guarantee it would work, but I'd make a bet in the favor of yes.
6/3/2022 3:17:05 PM • Gigabyte... • Answered on Jun 03, 2022
2answers
Asus p5gvmx vga driver win 7
The video chip is a IntelĀ® Graphics Media Accelerator 900 Use the default Microsoft driver, or the Intel driver at https://downloadcenter.intel.com/de/search?keyword=Intel+GMA+900+Xp+
7/18/2015 8:38:55 AM • Gigabyte... • Answered on Jul 18, 2015
Motherboard + processor compatibility
Yes you can use the processor on your motherboard. I hope my solution may help you. Thanks for using Fixya...;-)
5/6/2014 3:40:11 AM • Gigabyte... • Answered on May 06, 2014
Compatible processor
12/23/2013 9:35:43 PM • Gigabyte... • Answered on Dec 23, 2013
0answers
Vga compatible
Be the first to answer 8/17/2013 3:42:31 AM • Gigabyte... • Posted on Aug 17, 2013Be the first to answer
I need ga-8s661fxm-775 display adapter driver for
bvnhfbnfnb
7/24/2013 6:00:58 PM • Gigabyte... • Answered on Jul 24, 2013
Driver download
5/21/2013 3:05:26 PM • Gigabyte... • Answered on May 21, 2013
I need windows 7 vga drivers for Gigabyte GA-8S661FXM-775 .. any suggestions ?
click start right click on computer select properties device manager scroll to displayadapters expand right click select update driver software windows 7 should automatically search for and find the correct driver if it doesnthttp://download-drivers-free.com/bios/gigabyte/driver-gigabyte-ga-8s661fxm-775-rev-20-fa/or
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivershope this helps
9/14/2012 7:25:10 PM • Gigabyte... • Answered on Sep 14, 2012
The sims 3 desiel stuff pack pswoorrd
Hi'Please go to www.downlod.com
6/18/2012 4:34:34 PM • Gigabyte... • Answered on Jun 18, 2012
Acer aspire kav60 cant reboot to win 7
Why not? What happens when you press the power button to boot the computer? When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
5/25/2012 2:35:49 AM • Gigabyte... • Answered on May 25, 2012
Realtek ALC655 @ SiS 7012 Audio driver
Go here to get the driver you need. Just select the operating system you need it for and then select the Realtek AC97 Driver:http://www.gigabyte.com/products/product-page.aspx?pid=2186#dl
5/22/2012 4:21:12 PM • Gigabyte... • Answered on May 22, 2012
GA-8VM800M AUDIO DRIVERS
Go to this site for you to download your audio driver..Just click this link
7/12/2011 8:34:28 AM • Gigabyte... • Answered on Jul 12, 2011
2answers
I want to know if
Here is your answer: http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Look up your motherboard in the hardware section and you will have the answer.
6/20/2011 11:48:05 AM • Gigabyte... • Answered on Jun 20, 2011
I installed win7 and my
Go to product site link
LAN Driver
and choose your OS and download LAN driver.
Thanks for using FixYa.
5/31/2011 3:59:55 PM • Gigabyte... • Answered on May 31, 2011
Computer begins to power up, then immediately
Hi!
It sounds like a hardware problem... [Unless you'd say it reboots (always) right after the Windows logo - Is it the case??]
To resolve your problem, follow these steps:
1. Shut down the computer and disconnect it from the power cord and optionally from all the cable attached to it.
2. Open the computer case.
3. Look for blown capacitors on the motherboard, especially around the CPU area. If you've found any, I'm afraid you'll have to replace the motherboard, as it's unrepairable (and if someone claims it is - it's not reliable and won't last long)!
4. Clean from dust!!! Give great attention to the CPU fan (the one that attached to the motherboard) and the heatsink (the metallic part beneath it). Over-heating due to lack of proper ventilation for the CPU is the #1 cause for frequent reboots/shutdowns.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck & best regards,
Pelu.
4/26/2011 4:52:37 PM • Gigabyte... • Answered on Apr 26, 2011
I have a compaq presario
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive or click startcontrol panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart do not do anything while the chkdsk utility is in progress any input may damage your computer then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your (((motherboard to your hard drive))) do not do anything while the chkdsk utility is in progress any input may damage your computer then click start all programs accessories system tools defragment your hard drive you might have to install more RAM random access memory to check how much ram you have to check the details on your computer click start all programs accessories system tools system imformation all of your computer imformation will be there or click start right click on my computer select properties you will see all imformation about your computer including installed ram scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
http://majorgeeks.com/SiS_UniVGA5_Graphics_Driver_For_Windows_7_d6264.html if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! red x right click select reinstall drivers hope this helps http://majorgeeks.com/SiS_UniVGA5_Graphics_Driver_For_Vista_d5611.html http://majorgeeks.com/SiS_UniVGA5_Graphics_Driver_For_Windows_7_d6264.html hope this helps
3/28/2011 12:40:03 AM • Gigabyte... • Answered on Mar 28, 2011
GA-8S661FXM-775 (4719331838096) Motherboard: The Gigabyte motherbord onboard sound did not work...
If you need sound
1. You have to install UAA(Universal Audio Architecture).Click Here to Downlaoad it .
2. Then if you dont have the audio driver you can download it from here
1/30/2011 12:47:32 PM • Gigabyte... • Answered on Jan 30, 2011
Gigabyte GA-8S661FXM-775 (4719331838096) Motherboard Logo
44 questions posted
Top Gigabyte Computers & Internet Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gigabyte Computers & Internet
Most Popular Question
compatible processor
  • Computers & Internet
