20 Most Recent
Jane Rider Pushchair in Buganvila Questions & Answers
Jane Rider front wheel swivel problem....they get stuck.
We have had exactly the same problem. We took the pram back to where we purchased it from and got the pram fully serviced, the back tyres were changed for a better quality all terrain one, and the front tyres were also changed with new bearings fitted. It works as good as new now, however I still think this is only a temporary solution... Interestingly we have only used the pram (from new) for just four months before the tyres completely deteriorated and we found the manoeuvrability a major problem.
The front wheel wobbles when it's on swivel, what
The wobbling front wheel problem is easily solved. Simply remove the two philips screws from the plastic cap covering the from wheel assembly on the foot plate. (Where the break cable goes into the swivel tube) Now tighten up the large black nut with a spanner, replace the black cap and your done!
I am thinking about buying a jane tandem stroller.
Although I don't have the exact dimensions, these are pretty accurate and are for the chassis folded with the wheels off:
Length 87 cm
Depth 46 cm
Width 62 cm
If you are wondering if it will fit into the boot of your car, go and see if a stockist has one that you can try first!
I hope this helps.
