Turn the Master ON/OFF Switch to OFF and unplug the unit for 15 - 20 minutes. Hopefully, during that timeout, the electronics reset and reverted back to the original factory settings.You can then, set the controls as you like.
I hope this helped you. Thanks for choosing FixYa.
That should only be a temporary fix...if you let it like that the coil could freeze completely over causing major water damage...
The most likely causes are a plugged air filter or an under charged condition...the under charge is a sympton of a refrigerant leak...just adding refrigerant sill only solve the problem for a short time...
Here is a tip about trouble shooting your air conditioner...
Air Bocahttps://www.airboca.com > what-to-do-if-your-ac-has-...
Nov 14, 2022 - Additionally, a common cause of blown fuses (and trips to the AC ... on the fuse, you can inspect the access panel of your air conditioner.
"); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 62px;"> Rating: 4.7 · 285 votes
Missing: Fedders A6Q10F2A
Stack Exchangehttps://diy.stackexchange.com > questions > why-does...
Sep 7, 2013 - Which fuse is blowing? There are 4 common locations for fuses: main fuse panel for air handler, main fuse panel for condenser, local disconnect ...
6 answers · 1 vote: Long-term darkening of a fuse on a high-draw circuit like an AC is not unusual. How
