Unplugged unit first. Take control panel out but dont unplug wiring. Cut Firth wire out from the center on the touch pad six wire plug. Cap both ends and plug back in. now unit will run on high cool and turn it on and off by plug and unplug
Clean the outdoor coil, slide the unit out of the case, take a garden hose and nozzle to it use a solid stream of water, and watch the fins that you do not damage them with the water. Clean the indoor coils as well, and check to see if the motor is oilable. Keep the water out of the other components.
With a glass cutter, you could cut the glass to the correct size and using some angle aluminium strip and some silicone, then seal between the unit housing and glass. Hope this helps
Air Bocahttps://www.airboca.com > what-to-do-if-your-ac-has-...
Nov 14, 2022 - Additionally, a common cause of blown fuses (and trips to the AC ... on the fuse, you can inspect the access panel of your air conditioner.
"); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 62px;"> Rating: 4.7 · 285 votes
Missing: Fedders A6Q10F2A
Stack Exchangehttps://diy.stackexchange.com > questions > why-does...
Sep 7, 2013 - Which fuse is blowing? There are 4 common locations for fuses: main fuse panel for air handler, main fuse panel for condenser, local disconnect ...
6 answers · 1 vote: Long-term darkening of a fuse on a high-draw circuit like an AC is not unusual. How
