20 Most Recent
GE APN08AA Portable Air Conditioner Questions & Answers
Leaking water
Connect the proper sized tubing, and run it to a desired drain area. Make sure no outside air is entering the conditioned space.
Why is this blowing hot
The hot air is heat from the cooling compressor, while it's in operation. It's normal and should not be of concern, as long as the unit is cooling as it should and the host air is being exhausted out the flexible hose to the window.
Hope this answered your question and thanks for choosing FixYa.
I just purchased a souleus 12000 btu portable air
First, you need to determine what, besides the Souleus, is on that electrical circuit, and whether the circuit is 15 or 20 amp.
12,000 BTU A/C's tend to pull 10-12 amps, and they can peak just under 15 when the compressor starts. So a new, right off the shelf unit will max out a 15amp circuit. An older model with a worn out starting cap will demand even more amps at compresser startup.
Does the ape08akm1 operate safely
hello,
the solution to the question you ask is YES
but you will still have to be cleaning up the system once while in other to be looking good all the time
thank you and thanks for using fixya.
Hot air
if the evaporator coil on it ices up the thaws then ices up again your low on freon/refrigerant some use R-22 freon and some newer units use R-134a refrigerant,you can look and see if the condenser and evaporator coils need cleaning because if they get dirty and cant get rid of heat and it will build too much head pressure and the compressor will cycle off to protect it,but it sounds like a low refrigerant problem
Wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
