20 Most Recent
3Com 4500 24-Port Ethernet Switch Questions & Answers
I want to know the
Username:monitor Password: monitor---monitor mode, view only
manager manager--can change all except security features
admin (no password)--sets security features
IP: 169.254.100.100 or 169.254.100.99
7/18/2011 7:46:27 AM •
3Com 4500...
Answered
on Jul 18, 2011
Forget IP Address and configuration
to verify the ip address click start run and type in cmd then click ok then it will go into the dos mode in that page type ipconfig /all you will see all the ip adress
5/1/2011 1:49:42 PM •
3Com 4500...
Answered
on May 01, 2011
I have a 3com 4500
From your scenario what i guess is the two 5500's (A&B) are connected to each other also. Thats why the link between B&4500 is remaining down due to STP ( to avoid Network loop).
Please correct me if I am wrong.
What is the status of the link connecting 4500 to 5500 B when 500A is active and when 5500A is down .
If you are running STP i will suggest you to wait for 2 minutes after 5500A goes down and STP will be recalculated and the link connecting to 5500B will become active and then the route will also become active.
Best regards
11/3/2010 4:20:23 AM •
3Com 4500...
Answered
on Nov 03, 2010
Sir I have 4200 series
If you are creating only Layer 2 VLANs on the switch , you wont be able to ping the servers and Routers as they are in default VLAN1.
you can do the below steps
1. Create sub interfaces on the router LAN interface
2. Provide a new ip range to the new sub interface
3. Make the switch port connecting router as trunk, so that it will carry both the VLAN info
4. on your Labtop/PC give the IP address in the newly defined range
5. Make your switch port to be in the new VLAN
This will work , if you wont be able to configure the above settings, let me know i will give you the detailed config
11/1/2010 11:55:57 AM •
3Com 4500...
Answered
on Nov 01, 2010
Routing vlans on 3com switch 4500
i can't set ip address over 4 vlans. the 3com switch 4500 always give error message "there's not enough routing resources available".please help....
6/8/2010 12:51:47 AM •
3Com 4500...
Answered
on Jun 08, 2010
I cann't connect to my switch
The primary connection method for those switches would be serial connection. In the box there should have been a DB9 serial to RJ45 cable. Hyperterminal default settings would allow you to connect.
10/19/2009 8:52:15 PM •
3Com 4500...
Answered
on Oct 19, 2009
How can i access it using telnet?
if it allows telnet sessions, you would go to a command prompt and type:
telnet 192.168.1.2 (or whatever the IP address of the switch is.)
6/25/2009 7:05:43 PM •
3Com 4500...
Answered
on Jun 25, 2009
I have AVI Video and it only plays sound
Ok it is may be do you to system is old needs up to date , so that the video may not have downloaded completely from the source web portal. The media player present in your handset is outdated.
Db9 rj45 pinout
Here is the standard pinout for a console port on a router to seriel port for computers
HI,
I have two 3com
I don't know anything about these units, nor do I have time to source any docs for you, but maybe you can try connecting a PC directly to the port your patch panel is connecting the the switch from, you can at least see if that port is working.
My next and only other suggestion is to invest in a "LAN cable tester". In my area, you can find cheap ones for U$20.
The tester will allow you to check connectivity between any two ports, and allows you to test both patch links and individual CAT5/6 cables.
