20 Most Recent
Klipsch Promedia 2.1 Thx Certified Computer Speaker System Questions & Answers
No sound from my klipsch r-4b subwoofer
Klipsch is not forthcoming with internal diagrams. I have worked on / repaired some of them. They have components that are under rated for the application and fail. You will need to have it serviced if it pairs and you dont have sound.
Can I turn down the bass on my Klipsch rp280f speaker? I have no tone control on my sprout 100.
No.
The RP-280F is just a passive floor standing speaker.
Passive means it does not produce any type of audio/sound itself. It must be powered by an external amplifier or other source of power outside from itself.
Therefore it cannot/does not adjust or modify the power & or frequencies provided by another product.
Usally your adjustments for bass & treble are located on the receiver/amplifier/stereo/whatever your power source is & is adjusted by the product that is producing the power.
Hope this helps.
I have a klipsch promedia ultra 5.1 speaker system. On the back of the subwoofer it has three 3.5mm inputs for front L/R, rear L/R, and center/sub. What do the other ends of the 3.5mm cables plug into
Those three analog inputs are designed for a 5.1 or higher computer sound card (front, rear, and sub/center) with analog outputs. Onboard sound cards are mostly poor quality, so the Klipsch will not sound as good as if you have a better internal or external sound card (such as Creative's Sound Blaster, e.g., SB1). If you only have a digital surround sound source, such as a TV, Xbox, satellite or cable receiver, then you need a digital to analog decoder. Klipsch made a nice decoder, the DD-5.1. It converts optical and other digital signals to the analog signals your Klipsch ProMedia uses.
My Klipsch cs 500 has no sound. Blue light is on and I have tried every combination on remote to no avail. Any ideas?
There is the panel mounted 4amp fuse, and then there is a circuit mounted 6amp inline fuse as well. Mine blew due to a power surge that blew up other things in my house as well. It’s a bear to get the circuit board screws off, and some green sealant off! Step 1) I’m ordering a panel mounted fuse holder that is the same style as the 4amp fuse holder. Step 2) drill hole in panel, and install fuse holder Step 3) no need to remove old fuse (since its blown) so I’m soldering wires from new fuse holder to the fuse ends on the circuit board
