20 Most Recent Toshiba Tecra M1 PC Laptops Questions & Answers
I have a toshiba tecra
5/8/2017 6:30:17 AM • Toshiba Tecra M1... • Answered on May 08, 2017
I want to use my Tecra on channel 13
There is an extensive guide here on how to configure your NIC in Puppy Linux: http://www.murga-linux.com/puppy/viewtopic.php?t=22469 The commands you might be looking for could be: iwconfig wlan0 channel 6 iwconfig wlan0 essid pup2pup (pup2pup is just an example) iwconfig wlan0 key 1234567890 restricted (the numbers are just an example for your wifi key).
3/29/2016 2:07:08 PM • Toshiba Tecra M1... • Answered on Mar 29, 2016
My laptop has just frozen - died !
a slide on the back of the battery google that brand battery . see
11/28/2014 8:08:03 PM • Toshiba Tecra M1... • Answered on Nov 28, 2014
Lan card not working
Try reinstalling the LAN driver. You can download the LAN and device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
1/3/2013 12:35:39 PM • Toshiba Tecra M1... • Answered on Jan 03, 2013
3answers
Toshiba tecra m1 drivers free download
Try this link. http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK
This is the UK site i use. You just fill in the details in the drop downs and it will give you all the drivers you need
10/23/2012 12:06:05 PM • Toshiba Tecra M1... • Answered on Oct 23, 2012
2answers
Built in HDD pasword
i reckon i can help you sort this Problem Out.
I,ll give it My best Shot.
The First Thing To do Is To turn off the power, and remove the battery.
Then Remove the Hard-Drive, Should Be In A Drive-Bay Underneath.
9/6/2012 6:35:56 PM • Toshiba Tecra M1... • Answered on Sep 06, 2012
How to disable the tecra m1 power saver feature
Go into the control panel and select add and remove and look for the Toshiba Power saver utility and click remove. If you are running windows 7 go to my computer and select uninstall at top.
6/8/2012 10:18:06 PM • Toshiba Tecra M1... • Answered on Jun 08, 2012
4answers
Request for password
There are a lot of Windows password revealers and crackers available, but I’ve found that Windows Password Recovery Tool is the most effective.:
it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password
You can use the ISO to burn a boot CD. Follow these instructions:
1. Download ISO file from http://www.windowspasswordsrecovery.com Windows Password Recovery Tool
2. Burn to a CD using a CD burning tool such as Nero or Roxio or MagicISO
3. Insert CD into drive and reboot.
4. You may have to select an option in the BIOS to get the computer to boot from the CD.
Booting up and clearing a password takes a minute or two works like a charm.
5/21/2012 1:39:34 AM • Toshiba Tecra M1... • Answered on May 21, 2012
Need driver to play video
Try using VLC as your player. Go to www.google.com andin the search box type "download vlc" (without the quotes). Look for the Video Lan download from site www.videolan.org/vlc Downloadand install it. It downloads and installs in 3 minutes or so. It'sa very fast player, smooth and it can play just about any type of dvd formatsand media. It's totally FREE.
5/16/2012 1:11:13 AM • Toshiba Tecra M1... • Answered on May 16, 2012
Toshiba Tecra M1 what are hdd format procedure?
Formatting a laptop is the same as doing it on a desktop computer.If you are using the Windows installation CD then to get the laptop to boot up with the Windows CD you can change the BIOS boot startup device and make the CD the first boot device.
4/25/2012 10:17:22 AM • Toshiba Tecra M1... • Answered on Apr 25, 2012
Toshiba tecra m1 pc.. boot
If it's rebooting when trying to boot into safe mode as well, have you tried "Last Known Good Configuration"? Press F8 like you do to go into Safe Mode, and choose this instead.
If this doesn't work, on the F8 menu, you can disable automatic restart. This will cause Windows to hang instead of automatically rebooting when it encounters an error. With any luck, it will display a STOP error for you. If you get this, comment with the error and I'll be happy to look that up for you.
If this helps, please give a positive rating.
7/5/2011 2:44:32 PM • Toshiba Tecra M1... • Answered on Jul 05, 2011
Hello , i can't search
You can download thevideo and device drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
7/2/2011 5:29:48 AM • Toshiba Tecra M1... • Answered on Jul 02, 2011
I bought a toshiba tecra
Please get the driver here :
www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav...
Regards, Jay__cvf
3/2/2011 4:21:15 PM • Toshiba Tecra M1... • Answered on Mar 02, 2011
Tecra m1 boot option
when computer starts up push f2 or f12 what ever your boot formate is on system its the lower left side of screen when first starts up.
2/17/2011 2:16:55 PM • Toshiba Tecra M1... • Answered on Feb 17, 2011
My tecra m1 os
place XP CD into your CD Drive that is set to boot first in your Bios.
And reboot, When prompted (usually one of first things) press any key to boot from CD" do that....
once you get to the screen that loads press ENTER to "set up XP now"
Then press F8 for the user agreement
The next page will show your previous installs.
choose yours..
Select "Install a Fresh Copy of XP without repairing"
the next page will show some options with your drives and partitions listed below.
from there you want to select the partition with your current XP install,
Then smash "D" on your keyboard to delete the partition (this is where all data is lost on the drive)!
you will need to press Enter on the next page to confirm.
and another confirmation press L
next you will see your drive press C to create an new partition
next you can just hit Enter to create partition the full size of your drive. (suggested) or you can change the size and have multiple partitions.)
once you have created the partition press Enter to install
windows will tell you the drive is not formatted and will offer you
some choices... choose NTFS Quick or Slow ( I use slow on smaller drives and quick on the big ones.)
2/8/2011 7:02:42 AM • Toshiba Tecra M1... • Answered on Feb 08, 2011
Runs very very slow
Do you have any applications running that are consuming resources?
Can you please go to "Task Manager" and then performance and see if your CPU or Memory usage is high, if so please close the application(s) that is using it.
Also make sure you dont have lots of applications starting when windows starts.
How much memory do you have installed?
1/28/2011 4:29:59 AM • Toshiba Tecra M1... • Answered on Jan 28, 2011
2answers
How to add memory. Remove keyboard? How?
go to the following web site and it will give you step by step instuctions. http://www.irisvista.com/tech/laptops/Toshiba-Satellite-1905/remove-notebook-memory-1.htm
Christopher Thrash
B52computers
1/9/2011 6:49:03 PM • Toshiba Tecra M1... • Answered on Jan 09, 2011
My laptop didn't work well
what exxactly is th eproblem?
12/22/2010 1:22:52 PM • Toshiba Tecra M1... • Answered on Dec 22, 2010
I las my startup passward i need to format my
Hiya
If you have the manual have a look to see how to reset or remove cmos battery which should or hopefully remove the password if you havent got the manual using another computer go to :-
www.toshibia.com and look for the manual download it and save it to the desktop or pendrive it should show you what to do
12/1/2010 3:22:37 PM • Toshiba Tecra M1... • Answered on Dec 01, 2010
Toshiba Tecra M1 PC Laptops Logo
104 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Tecra Toshiba
  • Tecra Toshiba
Most Popular Question
toshiba tecra m1 pc boot
  • Computers & Internet
