20 Most Recent
Tacsew T500 Questions & Answers
REX blind stitch hemming machine motor quite hot. Locking the sti
When you tighten the belt it is a problem if it isn't adjusted right. You need to loosen the belt again. When you are pushing on the foot control the motor will begin to run. At the same time you can adjust the belt by carefully moving the motor. You will notice the motor speed will change as you do this. Stop adjusting the motor belt when you hear the motor speed at it's highest speed. Tighten down. Now, give it a try.
2/27/2017 3:14:57 PM •
Tacsew T500
Answered
on Feb 27, 2017
Looking for belts
The belt on my hemmer broke. I was able to find a vacuum cleaner belt the same size. Had to go to one of those local sew and vac shops and the guy measured it and found one for me. Only cost me a couple of bucks so I got a few of them.
9/13/2013 9:02:13 PM •
Tacsew T500
Answered
on Sep 13, 2013
Why does my T500 sometimes stop
if the machine has been sitting for awhile and you oiled it that willhelp, it could be the belt is too loose or the motor is going out or thefoot pedal needs to be checked to see if something is wrong with it.it would be a good idea to have the machine checked at a sewingmachine shop.
10/20/2012 1:31:02 PM •
Tacsew T500
Answered
on Oct 20, 2012
I am needing a replacement
try these websites
sewingmachine.com
allbrands.com
amapparelsupply.com
sewandserge.com
ebay
industrialsewingmachineman.com
9/5/2011 4:21:26 AM •
Tacsew T500
Answered
on Sep 05, 2011
Timing procedure
What happens to be the problem with the timing procedure? Please give more concise details to enable me profer a reasonable solution.
Hoping to hear back from you.
3/14/2011 2:03:36 PM •
Tacsew T500
Answered
on Mar 14, 2011
