20 Most Recent Candy CDV262 Dryer Questions & Answers
Replaced heater element on candy tumble dryer
How do you change the heater element on goc 580c
1/18/2015 2:23:35 PM • Candy CDV262... • Answered on Jan 18, 2015
0answers
0answers
8kg Candy Condenser dryer keeps stopping and
Hi Andrew, Nothing I found on-line worked. So tonight I had a good look. Inside the machine at the back of where the water caddy fits there's a reservoir. This was full but oddly the water caddy was empty. On the caddy there's a spout with a valve, inside it was fine dark fluff which was being compressed every time the caddy was reinserted. I picked this out with a little stick. I also, and this may not be necessary, removed the valve socket that the caddy valve goes into. It's attached by three screws to the bottom of the machine. This was also clogged with the same sort of fluff. Both blockages were stopping water passing freely into the caddy and so water built up in the reservoir tripping the empty light. Something to check for. Anyway mine works fine now and thought I'd share. Best regards, Ed
12/5/2012 3:18:01 PM • Candy CDV262... • Answered on Dec 05, 2012
Where do I buy a Candy CDV262 Dryer belt
Does this help? http://compare.ebay.com/like/390119133891?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y&cbt=y
6/30/2012 4:28:13 AM • Candy CDV262... • Answered on Jun 30, 2012
Candy dryerhi,we have a candy CC267T dryer. The
Hi.
There is a starter relay connected to the motor. The part must be replaced. Here the spare: RELAY PC.
Regards.
Ginko
9/22/2011 8:17:21 PM • Candy CDV262... • Answered on Sep 22, 2011
0answers
Candy nova cdv 262, heat
Hi dodgedrums...
I can answer your question, but you will need to resubmit your question if you need help in the repair.
I have never worked on a Candy machine so therefore I cannot help with the dissassembly of the dryer for repair
Your problem is most likely to be a broken belt, or a faulty motor...normally even a novice mechanic can repair with the proper advise which you will normally find here at Fixya.
Please take time to rate me
7/20/2011 3:13:02 PM • Candy CDV262... • Answered on Jul 20, 2011
Dryer doesn't seem to stop
If you are having dryer problems and you cannot even get the thing to start, then you might want to start going through this check list of possibilities. There are a number of things that can cause your dryer to not run.
A couple of the most common problems are the thermal fuse has blown or the door switch is not operating properly. On many dryers if the thermal fuse blows, the dryer will not run at all. This fuse can be checked with an ohm meter. It should show continuity if it is okay. If there is no continuity then you need to replace it and also find out what else failed. This is a safety device that usually blows because something else allowed the dryer to get too hot. It is usually located in the back of the dryer, on the blower housing. Some are oval in shape and others are rectangular, usually with two wires attached.
A defective door switch or a bent door switch lever can also cause you to have problems. If the lever is broken or bent it will not activate the switch. If the switch is broken, this also will not allow the dryer to be started.
The push (or turn) to start switch can go bad, but is unlikely. To check this, hold it in or turn it and then check to make sure you have continuity with an ohm meter.
If the dryer starts and then stops when the switch is released check the control board or the ?even heat? control on some model dryers. Some dryers have a belt break switch that can fail or your belt may be way loose or broken.
Check for burn marks or burnt wires at the terminal block on your dryer, poor connections can cause all kinds of problems. Also poor connections can cause fires.
A bad power cord also falls into this same category.
Of course, always check that you have the proper voltage to the outlet that you are plugging into.
http://www.fixya.com/support/r4312805-dryer_maintenance
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
6/6/2011 8:32:22 PM • Candy CDV262... • Answered on Jun 06, 2011
All lights flashing that the filters need
Quick searech on Google reveals that people are saying it only works in Summer, unless you put heater nnext to it to warm up the heat sensor, mental!
12/4/2010 10:49:04 AM • Candy CDV262... • Answered on Dec 04, 2010
Dryer makes a loud squeeking noise when turning
Here is a tip that I wrote about dryers and noises...It will help you determine what is happening there...Dryer Repair Squeaks, Grinding, Clicking and Knocking Noiseheatman101 Asker
11/23/2010 4:48:39 AM • Candy CDV262... • Answered on Nov 23, 2010
Candy CDV262 Dryer Logo
37 questions posted
Popular Products
Top Candy Dryers Experts
vince
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Candy Dryer Expert? Answer questions, earn points and help others
View Most Popular
Candy Dryers
  • Candy Dryers
Most Popular Question
all lights flashing filters need
  • Dryers
