20 Most Recent Tyan INTEL P4DPE-Q E7500 DUAL XEON SOCKET-603 VIDEO LAN E-ATX MOTHERBOARD : Questions & Answers
2answers
Forgat passward
To reset the password. Shut off the power supply, or unplug it. Press the start button. Remove the battery for two minutes. Replace battery Re-energize power supply.boot the computer to the BIOS.
7/5/2015 10:34:49 AM • Tyan INTEL... • Answered on Jul 05, 2015
Error code d4
There is a conflict in shadow ram. Check the add-on cards. It may be necessary to disable the BIOS shadow into RAM in order to make space for the other cards ROM
7/9/2015 6:53:23 AM • Tyan Computers &... • Answered on Jul 09, 2015
Red light 03 motherboard s5512wg
This error is "Initial Superio_Early_Init switch" This error occurs when The first memory module is bad or the BIOS is corrupt. Exchange RAM. If that does not work, Reset the BIOS by removing the battery for two minutes If that does not work, replace BIOS; or motherboard.
7/8/2015 5:59:09 PM • Tyan Computers &... • Answered on Jul 08, 2015
How do i reset the password on a Tyan m3296 SMDC
contact Tyan and request support, just say that the hardware was in a machine you were given. It might be that that there is a generic password built int the firmware. Such a practice is common on most electronic equipment, hope you are lucky. Otherwise look for an answer on Tyan forums or Tom's Hardware
5/25/2015 10:03:08 PM • Tyan Computers &... • Answered on May 25, 2015
Memory card slot jumper setting nokia 112
http://mobile-care.blogspot.com/2013/04/nokia-110-and-112-lcd-light-jumper.html
5/23/2014 4:25:02 AM • Tyan Computers &... • Answered on May 23, 2014
Motherboard tyan s5167
here you go http://www.tyan.com/support_download_manuals.aspx?model=S.S5197
5/18/2014 8:53:19 PM • Tyan Computers &... • Answered on May 18, 2014
Motherboard Led codes
Is this a bios error code onthe onbaord diagnostics? As this is a server board be careful - reset the bios to defaults is the first step in solving motherboard issues. Remove all cards and begin testing - remove all ram chips except one and test replacing stepwise until you have isolated the issue - usually the bios error code is the last item to pass before failure. Looks like it could be DMA controller failure but you would need the manual for the board to be sure.
5/13/2014 11:37:47 AM • Tyan Computers &... • Answered on May 13, 2014
USB 2.0 on Tyan S1845 Trinity 400 Motherboard
look at board near front panel on the sides
4/3/2014 4:45:38 AM • Tyan Computers &... • Answered on Apr 03, 2014
0answers
Tyan d1808
Be the first to answer 10/21/2013 9:15:04 AM • Tyan Computers &... • Posted on Oct 21, 2013Be the first to answer
Code e1 on a s2668
It is a bridge initilization error according to the manual. I would try removing the memory and just use 1 module and see what happens. If that doesn't work, try pulling other components, including the video card to see if you can isolate the problem.
10/31/2012 9:17:05 PM • Tyan Computers &... • Answered on Oct 31, 2012
I need to replace tyan s1854 trinity 400 m6tba
,HN,,HN
3/14/2010 12:31:52 PM • Tyan Computers &... • Answered on Mar 14, 2010
Hello, I am trying to install
Hi Can you tell me the brand and model of the mainboard and I'll get you what you need, those details read on the mainboard, the brand is often between the expansion card slots, Asus, Abit, Gigabit, and similar, it can also be between the cpu and the memory. The model is around the same area, if you are not sure, post me everything you find. thanks
12/1/2009 5:56:40 PM • Tyan Computers &... • Answered on Dec 01, 2009
D5 error on MB durring POST
i am william too i forgot password dell2400
10/22/2009 2:16:27 PM • Tyan Computers &... • Answered on Oct 22, 2009
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/25/2024 6:13:32 PM • Computers &... • Answered 8 hours ago
3answers
WHAT IS THE E MAIL FROM ECO BANK ALL ABOUT
Could be a phishing attempt, unless you have an account with that bank.
4/25/2024 5:54:17 PM • Computers &... • Answered 8 hours ago
Tyan INTEL P4DPE-Q E7500 DUAL XEON SOCKET-603 VIDEO LAN E-ATX MOTHERBOARD : Logo
1 questions posted
Top Tyan Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Tyan Computers & Internet
Most Popular Question
forgat passward
  • Computers & Internet
