20 Most Recent Siemens A55 Questions & Answers
0answers
Unlock code
Be the first to answer 4/30/2014 8:47:06 AM • Siemens A55 • Posted on Apr 30, 2014Be the first to answer
manual
A55 Manual
Siemens Cell PhonesUploaded on Oct 01, 2013
0answers
0answers
What is the network code for orange?
hi to get the network unlock code visit theunlockspot here they ask you the country and the network name to which your mobile is locked then the imei number of your mobile .finally they will send you the codes to unlock your mobile along with the instruction about how to use the codes in your mobile.
2/1/2012 9:06:48 AM • Siemens A55 • Answered on Feb 01, 2012
I bought siemens a55 usa ,use it in australia
You can remove the Sim lock from SIEMENS A55 easily using the Unlock code,get the Unlock code for SIEMENS A55 Model at here Onlinegsmunlock.com/unlock-your-phone/rs7wp2/ and Unlock it.
12/4/2011 2:48:54 PM • Siemens A55 • Answered on Dec 04, 2011
Codice di sblocco per siemens
hola puede utilizar c?digos para desbloquear el m?vil se puede obtener los c?digos de aqu? theunlockarena aqu? piden los siguientes datos antes de
que le proporciona los c?digos que son modelo de m?vil, el pa?s y el proveedor al que
el m?vil est? bloqueado. Por ?ltimo, le enviaremos los c?digos para desbloquear el m?vil. una vez que ha introducido los c?digos en tu m?vil como por las instrucciones
por los m?viles de su llave y se tendr? la libertad de aceptar cualquier tarjeta de red sim.
9/10/2011 6:43:42 PM • Siemens A55 • Answered on Sep 10, 2011
Unlock code for imei 352699002499427
you can get unlock code from here SimpleUnlocking.com to unlock your phone.
8/6/2011 7:42:46 AM • Siemens A55 • Answered on Aug 06, 2011
2answers
I would like to unlock my Siemens A55 phone
Get the unlock code here http://www.superunlockcodes.com/unlock-your-phone/rs12wp2/ and also get the unlock instructions in the same site.....
6/3/2011 10:37:11 AM • Siemens A55 • Answered on Jun 03, 2011
2answers
Got my old Siemens A55 back, but Orange locked.
You can get the unlock code here http://www.superunlockcodes.com/unlock-your-phone/rs12wp2/ and also get the following instructions in the same site...
1 - Switch ON your Siemens A55 with a NOT ACCEPTED SIM Card.
2 - Compose : *#0000*CODE#.
3/13/2011 1:11:59 PM • Siemens A55 • Answered on Mar 13, 2011
Handset locked requires PUK number
Hi the PUK code is the security code for the sim card and not any code to do with the phone, all you need to do to get the PUK code is call your service provider.
your service provider wont charge for giving you the code as the code belongs to you, all you need to tell them is your phone number or if you dont know that then the number printed on the sim card, they will then provide you with the 10digit PUK code for free over the phone.
this will then allow you to access the sim card.
The only place you can get the PUK code from is your service provider as their is no where else that keeps these codes, if you still have the card the sim card was attatched to then it will be written on their but if you no longer have this then the only way your going to get the code is by calling your service provider, they wont charge you for this as the code belongs to you,
you do have another option open to you though, if you dont need that sim card then you can go out and get another sim card and when you get given a new sim card you will get given the unique PUK code it will be written on the card the sim card is attatched to.
let me know if you need further assistance ok.
plz rate this solution as i have a whole page of unrated posts, thanks
3/3/2011 1:47:19 AM • Siemens A55 • Answered on Mar 03, 2011
A55 Orange GPRS Internet setup
Hi, the problem you are having is with the settings that are stored on your phone, the chances are these have never been setup correctly and you usually get this problem when you change the sim card in the phone to another sim or another network.
now all you need to do to solve this problem is call your service provider and tell them the make and model of phone you have got then ask them to send you the latest mms and wap settings.
your service provider wont charge you anything for doing this and they will send you the settings via text message this will then update your phone to the latest settings and you will be able to use the phone as you want to then.
you can sometimes send the settings to the phone yourself via your service providers web site, but not all service providers offer this service so you would have to check.
the quickest and easiest way would be to give them a call and ask them to send you the latest settings. they will do this for free so just give them a call and your phone will be then set up correctly.
1/2/2011 7:24:35 PM • Siemens A55 • Answered on Jan 02, 2011
What does phone disabled! network lock mean
it means the network has barred the phone, probably stolen
12/27/2010 6:39:01 PM • Siemens A55 • Answered on Dec 27, 2010
3answers
How do I unlock my Siemens A55 PM mobile phone
enetr the valid code which u had saved...........or if u had not saved any codes then the defaults code will be 0000 or 12345...........this will unlock ur phone
12/17/2010 9:59:07 AM • Siemens A55 • Answered on Dec 17, 2010
Puk code?
Puk code retrieval
Well, the first thing you need to realise when you read this, is that your puk code is a personalized code.
This code is unique to your phone, thus, there is no standard code you can type in.
The only way that you can retrieve your code is to have a look on the package which your sim card came in.
Your Puk and default pin should be stated clearly on the card.
Otherwise, you need to call your service provider from a sim which is from the same provider.
This is a toll free number, thus, you will not be charged. Explain to the assistant that you need to retrieve your puk code.
They will ask you your phone number and give you your puk.
Once you have your puk code, you will be able to reset your pin code.
Kind regards
Andrea
10/16/2010 2:18:44 PM • Siemens A55 • Answered on Oct 16, 2010
Unlock siemens a55
Welcome to FixYa
Dear User
To unlock a phone you will first need an unlock code Click here .You need to Know IMEI of your Phone and Enter it when trying to find an unlock code[Select your Model as in Left side/Click on Picture of Model you have and Follow Steps]..
Thanks for Connecting FIxYa...
10/5/2010 12:03:26 PM • Siemens A55 • Answered on Oct 05, 2010
Network lock on Siemens A55, need to unlock to insert new sim
You can get the unlock code here http://www.theunlockspot.com/ and also get the unlock instruction in the same site....By using this you can unlock easily....
9/4/2010 7:24:20 AM • Siemens A55 • Answered on Sep 04, 2010
Cell Phones Logo
48 questions posted
Top Siemens Cell Phones Experts
Paul Bade
Ngoro
john h
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Siemens Cell Phones
  • Siemens Cell Phones
Most Popular Question
codice di sblocco per siemens
  • Cell Phones
