20 Most Recent
Panasonic NV-GS35 Mini DV Digital Camcorder Questions & Answers
MY VIDIO CAM SOFT. CD
You can download the software and drivers from the panasonic support page for your product, I'm posting the link to the page below.
http://www2.panasonic.com/consumer-electronics/support/MiniDV-Camcorders/model.PV-GS35
7/2/2011 5:38:18 PM •
Panasonic...
Answered
on Jul 02, 2011
Auto focus is not working, inside or outside,
This happens when the internal focus lens is off track or impaired in some way and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
2/25/2011 6:15:47 PM •
Panasonic...
Answered
on Feb 25, 2011
I inherited my daughter's GS35
Your PC should have Windows Movie Maker installed as part of the OS. It will do the job if the Pansonic software fails.
Al
2/9/2011 11:32:26 AM •
Panasonic...
Answered
on Feb 09, 2011
How do I get the
You will need:
1. A video capture software such as Ulead VideoStudio 10
2. firewire or USB cable
1.Connect your camera with the cable.
2.Start Ulead VideoStudio 10
3.Go to Capture tab
4.Select your Panasonic device as the input for Ulead
5.Hit the "capture" button.
Ulead will start playing your video as well as recording to the PC at the same time
1/30/2011 2:07:35 PM •
Panasonic...
Answered
on Jan 30, 2011
When recording live music the
Option 1:
Check your audio settings on your camcorder. You may have an option to zoom in on the sound or record sound all around you. Try switching between either of those and see if that helps.
Option 2:
Add an external microphone
Option 3:
Try to muffle (lightly cover up) your onboard mic to keep the loud sounds from auto adjusting the volume.
1/11/2011 8:40:23 PM •
Panasonic...
Answered
on Jan 11, 2011
I have a Panasonic NV-GS
hi,dew means you got humidity level to high inside the camera
,press eject,removed the battery and try to use an air dryer an blow air inside the mechanism
thats where the dew sensor is located , for few minutes the let it cool down in a dry place
thats should reset the sensor system, if its not work that mean you will have to
replace the dew sensor.
hope that will help you,thats all i can do from here.
regards Alan.
12/25/2010 4:30:12 PM •
Panasonic...
Answered
on Dec 25, 2010
My camcorder comes up with a repeated message
First try removing all power from the camera, the main battery, any power supply, and the backup clock battery. THEN press the reset button and hold it for at least 15 seconds. Then replace the internal battery if it is dead. Then if the camera still does not operate correctly, it probably needs repair.
11/30/2010 9:50:05 PM •
Panasonic...
Answered
on Nov 30, 2010
I have a panasonic gs39 cam corder and can't
You can fit an add-on Firewire (DV) interface card to a PC that has expansion slots (not a laptop). These are available cheaply from Amazon or eBay, and other suppliers. There is also apparently an adapter to connect firewire into a USB port, but this is reported not to work well with video cameras.
11/4/2010 11:52:27 PM •
Panasonic...
Answered
on Nov 04, 2010
