20 Most Recent
Cyber Acoustics CA-5001 Computer Speakers Questions & Answers
Como hago para conectarlo directamente al
Home speaker systems experience malfunction either because the music being played is inappropriately recorded. First attempt to select from the list of media music or video to ascertain the condition as recording related. Second, the adjustments on the media player equalizers mentionable as bass or treble of teeters audibility makes the type of sound preferred. Open to display the computer media player to select from the audio sound adjustment qualities. Most computer media players have auto sound adjustments either mentionable as jess, pop, reggae, as only mandible examples of regulating the sound quality features. Navigate through the media player to ascertain the most appropriate volume; sound ratios require achieving pleasant listening experiences. For example, ascertain from the speakers systems for any available volume adjustment buttons. Also, the media player has adjustments to volume where the computer task bar area has adjustment volume bottoms. Observing queenly the sound features on the computer repair restoration functionalities.
No sound from them at
first right click my computer in the desktop then properties then hardware then device manager then expand the audio,vedio and game controller see wether the driver is installed properly if not installed it will show yellow question mark the reload the correct drives from the cd which you recived with your computer install the audio software and restart the system then in the taskbar you will see the speaker icon right click them click adjust audio properties in volume move the slisders to full on uncheck the mute then restart your computer
Forced 2.1 sorround sound on 5.1 surround sound
Swap the inputs around see what happens
Whether or not the out put is 2.1 or 5.1 has to be the nature of the signal going into the master unit
So have you got the sound card set up right- check sound card software.
Also check the Computer MoBo manual is there a BIOS setting that needs changing?
Also contact the makers website Tech Help if the manual is of no help.
take a look here
http://www.fixya.com/support/p39860-cyber_acoustics_ca_5001_computer
Why does my sub woofer not work
it could be a connection from not grounded to your aux cords being crimped and messed up could be amp or could be a setting on your radio..
Cyber Acoustics CA-3618 subwoofer cuts in and out.
Crackling noise and cut outs generally mean that the speaker is torn, or the cone is separated from the driver. This means the speaker is broken irreparably. It sells for $40 now, which means it is not worth fixing. These low cost speakers are built to not be taken apart.
