20 Most Recent
Panasonic KX-P7100 Laser Printer Questions & Answers
Clean a KX-P7100 printer
The paper jam in theKX-P7100 is usually due to the paper tray. If you pull the paper tray
out you'll notice a black piece of plastic (located at the most
front) with a cork like material in the middle. Try pushing down on this
piece of plastic a few times. If it does not pop up immediately the
grease that Panasonic used has become "sticky". The piece of plastic is
removed by turning the tray upside down and pushing on the small plastic
tabs that hold the black piece of plastic in. Be careful to not loose
the spring that is located under the black piece of plastic or break the
plastic tabs that hold it in place. Once you get the black piece of
plastic out, clean it with que tips and clean the area it slides up and
down in. Make sure to remove all the "sticky" grease. Once you get it
clean, don't forget to stretch the spring to one more inch. the spring quality
is awful at tensile strength. Then place the spring back in its place and push the black piece of
plastic back in its place. You can add some light oil to the black plastic to make it slide better. After it is reassembled try pushing down on
the black piece of plastic a few times. It should spring up almost
immediately. This should take care of the jams that you are
experiencing. In addition, you may have to stretch the 2 big springs under the metal plate in the
paper tray to one more inch. To access them, you'll have to unscrew the 3
philips screws under the tray (take a picture before :-)), take away
the 2 blue pieces and take out the metal plate.Now I'm able to print from the media tray without any problem :-).Hope this helps!
8/29/2013 10:24:41 AM •
Panasonic...
Answered
on Aug 29, 2013
KX-P7100 Printer was not listed
you can download driver and utility from "http://panasonic.net/pcc/products/printer/download/p7100download.html"
then you can set up new printer
must vote for solution
9/11/2010 5:26:26 PM •
Panasonic...
Answered
on Sep 11, 2010
As soon as the printer
Make sure there is not any paper jam inside the printer.
Open the side plate and back side of printer.
Then you can see fuser assembely.
Then make sure there is not any jammed paper and roller is working properly if roller is broken then you need to change it.
Then fix fuser assembely then check.
Let me know if you need further assistance.
Thanks for using Fixya.
4/26/2010 10:18:27 AM •
Panasonic...
Answered
on Apr 26, 2010
Jammed paper tray
Check your owners manual.
In that it is said how to open the tray from behind, if there is a paper jam.
You have to open it form behinnd.
4/9/2010 3:31:15 AM •
Panasonic...
Answered
on Apr 09, 2010
Paper keeps jamming
Turn the printer upside down and give it a good shake - could be something jammed in the paper feed.
4/28/2009 12:54:18 PM •
Panasonic...
Answered
on Apr 28, 2009
