20 Most Recent
3Com OFFICECONNECT Network Adapter Questions & Answers
Dell Driver Problem
Did the gh60 come with the Dell or was it added later?
Did you change the OS ? if so you need to go to dell and if the card is listed as per mfg you can get the driver for an updeted OS .
1/30/2009 4:36:49 AM •
3Com...
Answered
on Jan 30, 2009
No sound with my Cyber Snipa Scout Personal Webcam
Make sure that the microphone settings for your webcamera are enabled. Go into the control panel under sounds and audio devices. Make sure voice playback and voice recording are set for the web camera microphone and not the sound card.
6/22/2008 4:28:45 PM •
3Com...
Answered
on Jun 22, 2008
Pcmcia
6/19/2008 11:30:44 AM •
3Com...
Answered
on Jun 19, 2008
I have AVI Video and it only plays sound
Ok it is may be do you to system is old needs up to date , so that the video may not have downloaded completely from the source web portal. The media player present in your handset is outdated.
Db9 rj45 pinout
Here is the standard pinout for a console port on a router to seriel port for computers
HI,
I have two 3com
I don't know anything about these units, nor do I have time to source any docs for you, but maybe you can try connecting a PC directly to the port your patch panel is connecting the the switch from, you can at least see if that port is working.
My next and only other suggestion is to invest in a "LAN cable tester". In my area, you can find cheap ones for U$20.
The tester will allow you to check connectivity between any two ports, and allows you to test both patch links and individual CAT5/6 cables.
Facebook recovery
notify the police dept / person handling the case and let them know about the face book information
