20 Most Recent
Acer TravelMate C112TCi-SP2 Tablet PC Questions & Answers
Hi I have an Acer
Hi,Seems like your hard disk is not getting detected.Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.Start tapping the DEL key as soon as you power on the computer.This will take you to the BIOS screen.If it doesn't, you will have to check whether your hard disk is faulty with a local technician.Once you get in to the BIOS screen, press F9 to load the default settings.Than press F10 to save and exit.Once you do this, the computer will restart.Hope this helps.
Acer Travelmate C112TCi- Won't power on
Hi,Remove the adapter and the battery from the laptop.
DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Travelmate will not boot up
Not booting
Laptops:
1. Unplug Ac power cord and take out the battery
2. Press and hold power buton for 25 secs (yes without cord and battery)
Desktops:
How do i reset an iconia one 7 tablet
For hard reset
Follow these steps
1- First turn off your Acer Iconia One 7 B1-730 completely. If you can not unlock the screen, press and hold the power button for about 20 seconds and the phone will turn off.
2- Keep holding on volume down and power keys together for a few seconds. In some devices according to the Android version the combination can be the power key and the volume key up.
3- When the Acer logo is displayed, release the buttons.
4- Move through the menu with the volume up and volume down keys until you reach the "Recovery Mode" option and press the power button to access.
