20 Most Recent Bosch Evolution 500 HGS5053UC 30" Freestanding Gas Range with 5 Sealed Burners, 5 cu. ft. Convection Oven, Self Cleaning and Wide View Oven Window Questions & Answers
Bosch gas range error code F11
Disconnect the ribbon from the control panel and clean it using pencil eraser. then carefully reconnect it. If the F11 is still there most likely it's the control panel.God bless you
2/1/2013 6:14:19 PM • Bosch Evolution... • Answered on Feb 01, 2013
How to fix a Bosch Sensixx B7 faulty Spray function.
Thanks for that Tim, very useful indeed. Siri did well, but there were two typos which I fixed 'price', to 'prise' and 'stripey' to 'stripy'. These videos may have been helpful for Sensixx and may have been the ones you watched. Thanks again, much appreciated. .. https://www.youtube.com/watch?v=9kTFaHDxkG4
7/29/2023 4:35:10 PM • Bosch Irons • Answered on Jul 29, 2023
The temperature control dial of my Bosch Sensixx x DA30 iron has become very stiff to rotate. How to make it easier to turn?
If the temperature control dial of your Bosch Sensixx x DA30 iron has become stiff, you can try the following steps to make it easier to turn:
  1. Unplug the iron and let it cool down completely.
  2. Using a soft cloth or sponge, clean the dial and the surrounding area to remove any dust or debris.
  3. Apply a small amount of WD-40 or silicone spray lubricant to the temperature control dial.
  4. Slowly turn the dial back and forth a few times to distribute the lubricant and loosen up any dirt or debris that may have been causing the stiffness.
  5. Wipe away any excess lubricant with a clean, dry cloth.
  6. Plug in the iron and turn it on to make sure the temperature control dial is turning smoothly.
If the stiffness persists or the temperature control dial is still not turning smoothly, you may need to take your iron to a professional for repair or replacement of the dial.
2/25/2023 6:01:00 PM • Bosch Irons • Answered on Feb 25, 2023
I have a bosch vario comfort series 8 iron and steam release button pushed up inside it and it broke - can this be repaired
It would be more cheaper and easier just to buy a new clothing iron than to try and fix the steam release button on your iron.
6/14/2022 3:11:21 AM • Bosch Irons • Answered on Jun 14, 2022
Hi my Bosch steam iron is tripping my electric when I turn it on its brand-new anyone no what problem is ?
dead short in the iron or lead brand new , take it back for a new item under warranty
9/19/2019 7:09:39 PM • Bosch Irons • Answered on Sep 19, 2019
My bosch steam iron sensixx b25l keeps letting steam out continuosly without the steam switch being pushed, product is just 3 years old
Do you drain the vinegar before turning on the iron and steaming through?
2/4/2019 9:11:22 AM • Bosch Irons • Answered on Feb 04, 2019
I have an bosch sensixx b5 iron and the calc clean
Here you have how to solve this issue. It has been obtained from the device's manual.
2. calc'n clean The "calc'n clean" function helps to remove scale particles from the steam dispenser. The iron includes a system to warn when the dispenser needs periodically cleaning. When the "calc 'n clean" symbol lights up on the navigation display the dispenser needs cleaning. Fill the water tank. Plug in the iron and select the temperature setting . After the necessary warm-up period, unplug the iron and hold it over a sink. Position the steam regulator to the "calc'n clean" position and keep it in this position. Gently shake the iron. Boiling water and steam will come out, removing any scale or deposits that might be there. When the iron stops dripping, position the regulator to the position. For improved descaling, heat up the iron again fully and press the steam button several times in quick succession. Then wait until the remaining water has evaporated from the soleplate of the iron. Once it has been cleaned, the cleaning warning must be cancelled on the navigation display. To do this, simply press and hold the on/set navigation key for more than 5 seconds, with the iron plugged in. If you do not do this, the cleaning icon will remain lit. 3. anti-calc The "anti-calc" cartridge has been designed to reduce the build-up of scale produced during steam ironing, helping to extend the useful life of your iron. Nevertheless the "anti-calc" cartridge cannot remove all of the scale that is produced naturally over time.
7/8/2017 6:59:42 PM • Bosch Irons • Answered on Jul 08, 2017
Bosch Evolution 500 HGS5053UC 30" Freestanding Gas Range with 5 Sealed Burners, 5 cu. ft. Convection Oven, Self Cleaning and Wide View Oven Window Logo
2 questions posted
Top Bosch Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
Aron
Are you a Bosch Iron Expert? Answer questions, earn points and help others
View Most Popular
Bosch Irons
  • Bosch Irons
Most Popular Question
bosch gas range error code f11
  • Irons
