20 Most Recent
Antec : True430 430W P4 ATX Power Supply (PSAN06) Power Supply Questions & Answers
Is there a fuse
Yes there is, there is also a protection diode in line with the switch.
I have an Antec Truepower
Test it. Unplug the molex connector from the mothrboard. You can use a wire or a paper clip to test it to power on. You will connect (short) pin 14 to and ground pin. (
diagram here) For example, put one end of the paper clip into pin 14, and the other end into 13, 15, or 16. If the power supply turns on and fan running then maybe a problem with the front panel switch on the computer case.
P.S. make sure you unplug all other leads to drives before doing this.
ANTEC MODEL SP-500 POWER SUPPLY
It is best you replace this power supply.
These power supplies have dangerous voltages inside the unit and if you do not have electronic knowledge, any mistakes you make can be fatal.
HOW TO FIX ANTEC AR-352
Unfortunately, there are not many parts available off the shelf to repair these. It would be simpler to get a power supply with a greater wattage rating than the one you have now.
Cannot get to the internet
What kind of Internet connection do you have
DSL, Fiber, Cable? do you have a modem? Do you have a router? Are you connected via Ethernet cable or wireless?
In order to start any diagnosis I need the answers to these and maby some other questions
Weird start-up problem
Recheck all your board connections. I missed a connector by one pin and got nothing as you have. Once I realized my mistake and re connected the plug on to the board correctly everything worked.
