20 Most Recent Zanussi ZCG7550 Gas Kitchen Range Questions & Answers
Zannussi Gas cooker
make sure clock is set properly - refer to your instruction book. to test if clock is in fact faulty, access the clock and bypass it by shorting together the two wires to the clock relay
8/17/2008 4:26:35 PM • Zanussi ZCG7550... • Answered on Aug 17, 2008
2answers
Zanussi zcm1030x double oven repair manual
I would suggest contacting either the store you bought it from, or the manufacturer. Most of the time, they'll be able to help you out without too much trouble at all. If that doesn't work though, you'll probably want to call a technician who specializes in oven repair. That way you'll be able to get the repairs done properly, and you can be confident that you won't have to get it repaired again. http://repairmyappliance.nyc/services/oven-repair/
1/16/2023 8:14:19 AM • Zanussi Kitchen... • Answered on Jan 16, 2023
Can a zanussi cooker model number ZCG5000BKN be converted from NG TO LPG
You'll need to change all of the pilot light orifices to LPG size. You may have to replace the main oven burner assembly and the simmer burner/injector assemblies to accomplish this. (Essentially any part number with NG in the name should be replaced with the LPG equivalent.) The greatest difficulty may be finding the replacement parts, or paying for them; it may be more economical to sell the NG unit and purchase one already set up for LPG.
11/9/2021 1:42:00 PM • Zanussi Kitchen... • Answered on Nov 09, 2021
2answers
Can the Zanussi oven, set for LPG, model ZCG660GXC be converted to be used with natural gas?
Zanussi ZCG660 Manuals EW 1200 i on manualslib.com Dont know if you have a manual. On page 21 it says: Gas Category 13+ Gas Supply G30/31 (3+) - 28-30/37mbar page 22 shows more settings 20mbr for natural gas however instructions are not valid in all countries. I went to www.zanussi.com it asked pick country and Egypt I picked. There is a support tab see if that gets you closer than Italy or Switzerland. Good Luck looks like a great oven. Zanussi Start
3/31/2015 7:54:21 PM • Zanussi Kitchen... • Answered on Mar 31, 2015
Zanussi zce 7690 main oven
Thought someone may find this helpful. We bought our Zanussi ZCG7690XN just 4 yrs ago. For nearly 2 yrs the main oven control stopped working. Never got round to replacing the timer controls- ~£80 or so. Read through some threads and thankfully found a few helpful. What I found difficult after accessing the control unit was recognising the correct wires to connect so as to isolate(over ride) the timer unit. Finally sorted this and presto it worked. The same process may help those who wish to replace their unit with a new one.
For those who will try, take safety precautions. If the spark generator works, there is likely power to the timer unit (and oven). If not check fuse, confirm mains supply.
The control unit is accessed first by unscrewing top oven front plates to gain enough room. Then with a flat screw or similar tool, take off the two small clock knobs and the two adjacent burner dials. you would then need to undo four little screws two on each of the burner dials. You can now gently extract the controls from below -can be tricky, (may or may not require using a plier to bend a bit of metal). With the unit out, turn it upside down and you would be looking at the rear of the circuit board with a blue wire, two brown wires connected to the relays and a red wire feeding back to the main oven dial(beside the spark generator). A green earthing is attached to the side . Leave this alone. All you need to do is to join the red wire to the nearby second brown(live)wire. I did this using connectors. Any other sensible means should be fine. The blue wiring returns to the light bulb and back with the others to electrics at the back. I took this off the timer as well.
I previously had recurrent problems with the grill spark unit connection- burnt off. Sorted this out by fixing the connection (access from the front top oven, unscrew a small metal protecting plate to reach it).
I do apologise if some find this too lengthy. Any questions are welcomed.
4/23/2013 6:06:43 PM • Zanussi Kitchen... • Answered on Apr 23, 2013
0answers
Zanussi ZCG7550 Gas Kitchen Range Logo
Popular Tags
6 questions posted
Top Zanussi Kitchen Ranges Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
How-2-Repair.com
How-2-Repair.com
Are you a Zanussi Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Kitchen Ranges
Most Popular Question
zannussi gas cooker
  • Kitchen Ranges
