20 Most Recent Averatec C3500 Tablet PC Questions & Answers
Touch Screen Not Working
Try holding down the power button for about 20 seconds, this should hard reset the phone/tablet.
11/19/2013 12:34:20 AM • Averatec C3500... • Answered on Nov 19, 2013
2answers
Dissplay not working
I had the same problem on one that I bought, that was used. You have to take out all of the little grey plugs and remove the screws underneath them. My cables were all fine. I had a connection inside the monitor area, near the top. There is a ribbon cable with a flat, wide plug on it. I had to uncompress the sides of the plug & jack. It cured the problem. About 4 months after I had it working, I found out the previous owner used to pick it up by the screen.
12/15/2012 7:23:53 PM • Averatec C3500... • Answered on Dec 15, 2012
3answers
After re formating my averatec c3500 series touch
Your new install of Windows will be using generic drivers. You need to update to the specific touchpad drivers. Download them from Trigem (Averatec is a brand name owned by trigem) http://www.trigem.com/us/support/drivers.asp
10/24/2012 10:38:50 AM • Averatec C3500... • Answered on Oct 24, 2012
My touch pad will not
Sounds like the driver didnt get installed back onto your computer correctly. If you go here: http://www.trigem.com/us/support/drivers.asp and download the one that says touch pad and install it. You may need to get a external mouse in order to install and complete these actions in order to get your laptop mouse working again!
Best of luck!
Josh
5/6/2011 9:42:52 PM • Averatec C3500... • Answered on May 06, 2011
How do I convert hadwriting into text when
u can use any OCR optical Character Recognition that is available on the market
I would use Paperport software
Hope this helps
3/7/2011 6:39:46 PM • Averatec C3500... • Answered on Mar 07, 2011
My Averatec C3500 powers on all lights come on
hi
i found the Averatec link for support -- i was able to locate something may help you -- but if you are not egtting any viewing, then the LCD panl;e may be defective or dmagaed somehow.
go to this link , .. it may be brightness issue (hopefully)
http://www.trigem.com/us/support/faq_view.asp
1/9/2011 5:57:12 AM • Averatec C3500... • Answered on Jan 09, 2011
2answers
I need to know how to dismantle my averatec c3500
Mostly when I open some equipment and repair them, I used to go around the NET, but that YouTube greatly helps me a LOT in saving equipment, materials and money!
Just go to this site and have a great day fixing ur Tablet!
Just leave a nice comment thanx!
http://www.youtube.com/results?search_query=Averatec+C3500&aq=f
12/9/2010 4:00:01 AM • Averatec C3500... • Answered on Dec 09, 2010
Remove dvd drive
Get a paper clip and straighten half of it out. Now look for a small hole in the face of the DVD drive.
If the drive is Trayless then there should still be a small hole in the dvd location..If the DVD has a tray make sure that the laptop is powered down, insert the Paper clip in to this hole and the DVD tray will pop open.. If the DVD inserts in to the drive(Trayless), Then make sure the laptop is on and insert in to the hole that will be in this same area.
Thank you for your visit to Fixya.com
12/8/2010 9:17:16 PM • Averatec C3500... • Answered on Dec 08, 2010
How to change the CMOS battery?
You have the open completely your laptop, to the main board. Then you will see like a watch battery, that is the cmos battery. There isn't any other way to do this.
Regards!
11/26/2010 10:49:52 PM • Averatec C3500... • Answered on Nov 26, 2010
My avaratec powers on and
the system memory may cause systems to come on and off. Replace your system memory with a good one. if this problem continues, replace the processor
9/28/2010 8:05:07 AM • Averatec C3500... • Answered on Sep 28, 2010
Driver Download
8/9/2010 4:57:55 PM • Averatec C3500... • Answered on Aug 09, 2010
Lcd no display
mother board will be faulty get it tested ###www.aris.in###
5/27/2010 12:36:12 PM • Averatec C3500... • Answered on May 27, 2010
2answers
My computer shuts off after im on it for a while. too hot???
This video should help you. If not let me know and I will look for more options.
http://www.youtube.com/watch?v=Ed5VJqO21ns&feature=related
3/22/2010 5:51:48 PM • Averatec C3500... • Answered on Mar 22, 2010
Cracked screen computer working
Okay heres the thing, look up your model number on your laptop and check the model number in google, after you find your laptop look for a site that offers replacement parts, depending on the year of the laptop you can relativily pick up a screen for cheap, simply pull the small tabs that hold your plastic keyboard in place and lift it out gently (you dont want to damage the keys); then take apart the laptop as needed depending on the model it might only be two screws holding it in and you may not have to remove anything else, so anyway after you get past the hardware and gently dismantle your laptop, just remove screws and screen connector from motherboard (be sure to not touch motherboard or have it on any surface that might give you electrostatic discharge) which would fry your laptop. Then just swap out smashed screen for newly ordered screen and reassemble, not very difficult! Hard to give you any more info not knowing model or anything!! Good luck!!
2/27/2010 8:41:31 AM • Averatec C3500... • Answered on Feb 27, 2010
I press the power button, then fan begins to spin
You need a new processor
2/26/2010 1:04:38 AM • Averatec C3500... • Answered on Feb 26, 2010
My Averatec C3500 Tablet will come on but the
You need a motherboard
2/26/2010 1:02:02 AM • Averatec C3500... • Answered on Feb 26, 2010
2answers
How can I get a copy of the restore disk
Contact the manufacturer by email or telephone..
email: [email protected]
phone: (714) 429-8999
They are available 8AM to 5PM PST
2/6/2010 5:26:05 AM • Averatec C3500... • Answered on Feb 06, 2010
2answers
My Averatec C35009 has had
I believe the problem is the CD drive. You may be able to clean the cd with a cotton cloth and water.
I recommend you to clean the lens of the CD drive using a q-tip and some alcohol. Clean the lens carefully and let it dry.
If it doesn't work after the cleaning, you may need to try with an external CD drive (if available).
Here is how the lens looks like:
( http://s3.amazonaws.com/preview.canstockphoto.com/canstock0401581.png )
1/18/2010 1:44:15 PM • Averatec C3500... • Answered on Jan 18, 2010
Averatec C3500 Tablet PC Logo
52 questions posted
Top Averatec Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Averatec Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Averatec Tablets & eReaders
Most Popular Question
press power button fan begins spin
  • Tablets & eReaders
