20 Most Recent
Standard Ignition Knock Detonation Sensor Ks140 Mazda Questions & Answers
Do you have to reset after replacing knock sensor
I there is /was a engine code showing up you may need to reset the computer, more than likely you just need to drive the vehicle for some distance and the computer will reset itself.
If not, the easiest way would be to disconnect the negative battery terminal for 3 - 5 minutes, reconnect and start the vehicle letting it run for 15 mnutes,. should be all set.
8/12/2014 12:32:05 PM •
Standard...
Answered
on Aug 12, 2014
I need a head valve seat for central pneumatic 21 degree angle framing nailer model 60828 also need headvalve seat for 34 degree angle finish nailer 68020
I have not been able to purchase replacement parts for these nail guns , however, have repaired them using parts from Bostitch framers and or just make the part. If the seal fits over the top of the cylinder, then try using seal from Bostitch framer part #N70155 fits a bit tight but works. Heat with a hair dryer to soften and install. If the seat is incorporated within the head valve, just dig it out and replace it with liquid two part urethane. Just mix and pour it in. After cleaning out the old seal, place head valve on level surface and pour in the mixed urethane till slightly over full to give the seal a nice crown. The finish nailer might also be repaired using other brand of seals. Remove the old part and take it to service center for a possible match. Good luck with your repair.
