20 Most Recent
Epson Stylus Color 600 with GT-5500 Scanner InkJet Printer Questions & Answers
I was printing on a A4 thick (invitacion Card)
Make sure there is 1/16 to 1/32 inch space on each side of the paper in the paper tray.
Move the paper type selector back and forth 5 times, to make sure it is not stuck.
Feed the tray with a minimum of 20 sheets of paper and try to see if it loads paper through.
The paper thickness lever has two settings, one for plain paper, (thin paper 20# to 24#) and one for envelopes and thick paper.
It should be on the 0 setting for thin paper and on the + setting for thick paper and envelopes.
The paper adjustment lever may be adjusted in between the two settings to accommodate paper that is not standard or that the operating/environmental conditions have changed.
Make sure the paper is loaded far enough into the printer to ensure good contact between the paper and the paper feed mechanism.
EPSON STYLUS RX 520 HAS AN ERROR E-91
The error E-91 on an Epson Stylus RX 520 indicates a communication problem between the printer and the cartridge. Here are some steps you can try to resolve the issue:
- Turn off the printer and unplug it from the power source.
- Remove all the ink cartridges and check for any damage or leaks. Replace any damaged or leaking cartridges.
- Clean the metal contacts on the ink cartridges and inside the printer with a soft, lint-free cloth. Make sure they are completely dry before reinserting the cartridges.
- Reinstall the ink cartridges and make sure they are properly seated.
- Turn on the printer and see if the error message still appears.
If the error message persists, try resetting the printer by following these steps:
- Hold down the "Stop" and "B&W" buttons while plugging in the power cord.
- Keep holding the buttons until the printer starts to initialize.
- Release the buttons and wait for the printer to finish initializing.
- Try printing again to see if the error message is resolved.
If none of these steps work, there may be a hardware issue with the printer and it may need to be serviced by a professional technician.
HOW TO RESET THE COUNTER ON MY EPSON STYLUS SX415
Please attempt to factory reset your printer in order to reset the counter. If you don't know how to do this, please check the table of contents in your device's manual: https://www.manualslib.com/products/Epson-Stylus-Sx415-4234082.html . Thank you.
How to download epson adjustment program
On most Epson printers the Adjustment program can be accessed via the printers interface, without need to do it via a pc. Without knowing the model it is fairly difficult to answer this question more fully. However if you have a manual or can download the manual from epson.com, there will be a chapter on manual head cleaning and adjustment proceedures.
