20 Most Recent Generic Memory Mini Retractable USB Optical Mouse (COUSB) Questions & Answers
Am trying to fix my retractable mouse. do you have
No pix or diagram, but you'll see a coil spring that provides the retracting function, plus one very small ball bearing that provides the holding function. The ball bearing sits on a dimple in the case and "lodges" itself in a groove in the top plate, so that whenever you rotate the case all the way around once, the ball bearing falls into the dimple and locks the two pieces together until you yank the cord. The cord just wraps around the case and there is enough friction between the cord and the case that as you pull/slide the cord, it winds the spring.What happens most of the time is that the case/plate slips apart and the tension comes off, and/or the ball bearing drops out.I took the plate off the case (a small phillips screw), rewound the spring a couple of turns, rewrapped the cable, very carefully put the ball bearing in the groove, and put the screw back in. It was difficult, and you should do it with tacky paper on your work surface because I dropped the ball bearing quite a few times.Earlier in this column, someone said send it back in for warranty. almost worth it to do that, because the small pieces can be frustrating to deal with.
8/21/2012 12:08:19 PM • Generic Memory... • Answered on Aug 21, 2012
M trying to fix my retractable mouse. do you have
Optical mouse from inside: http://www.gadgetrivia.com/photos/o/56422-best_optical_mouse.jpg (this isn't a retractable mouse, but the inside looks exactly the same, only the cord this different which doesn't matter in this situation).
Here are instructions for optical mouse repair: http://www.thenetguruz.com/hardware/diy-optical-mouse-repair/
But if your mouse doesn't work first plug the mouse in the USB slot and check the laser beam under the mouse - if there is no light, the mouse is dead, and you should return it to the seller for replacement. (Such a thin cable of the mouse is very vulnerable and might break easily. More over I find many negative reviews about this rectractable mouse - so if your seller offers to replace it - ask for a different model or test it with your laptop right in the shop before bringing it home.)
2) Here is a solution that already worked for another user, but was very complicated: http://forums.toshiba.com/t5/Keyboards-Touchpads/USB-mouse-not-recognized-drivers-can-t-be-installed/m-p/23526
3) Or alternatively download and install a free driver updater software, e.g. http://www.innovative-sol.com/drivermax/index.htm - let it scan and update all your missing drivers - it may fix USB general problems if this causes also the mouse problems.
3/7/2011 2:10:59 PM • Generic Memory... • Answered on Mar 07, 2011
3answers
How do you block ads from Opera Browser
1.Firstly, open your opera browser
2. Open Tools ->Advanced->Blocked content
(whichallows you to block webpage content from the website)
3 A dialog box will appear and you need to list website or part of website to be blocked.
example:
http://pagead2.googlesyndication.com/*
http://ads.*
http://imgserv.ad*
hope this help
8/10/2022 6:34:56 AM • Generic Memory... • Answered on Aug 10, 2022
How to face code 43 error of bluetooth in win7 32?
HP bluetooth driver needs to be updated.
3/3/2013 12:48:03 AM • Generic Memory... • Answered on Mar 03, 2013
I can't send an Omniform attachment via Microsoft
I am not sure if this has been solved here but you can send the attachment as a zipped file. Right click on file. Choose send to. Choose zip file. Now attach zip file to email.
8/7/2012 1:31:35 PM • Generic Memory... • Answered on Aug 07, 2012
I installes a coxeant modem but i need the drivers
Try using this link to get the drivers for your modem, deppending on the system you have.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
5/10/2010 6:40:09 PM • Generic Memory... • Answered on May 10, 2010
My 500 GB external hard disk is not showing on my
Unplug the power cord on the back and replace it. The computer says 'new hardware detected' and on computer tab. Hope this works!!!!
3/3/2010 3:46:13 PM • Generic Memory... • Answered on Mar 03, 2010
I HIT THE CAPS LOCK AND IT SHUTS DOWN THE COMPUTER
Try to replace keyboard, you have malfunction in your keyboard.
3/1/2010 12:17:03 AM • Generic Memory... • Answered on Mar 01, 2010
How to install memory on ecs G550 laptop can only
There are two memory slots which support PC2700/333 Mhz memory, maximum 1024 per slot.
ECS suggests using identical/matched pairs of chips from the same manufacturer for their units.
In most laptops there is an access panel which when removed gives you direct access to the memory chips for replacement. I couldn't find a mainboard diagram for this unit so I am unable to see if the memory slots are adjacent on the board but there is little reason they shouldn't be. You should be able to access both slots once the proper access panel is opened.
This is the website page for direct contact with ECS tech support if you have any further questions: http://www.ecsusa.com/ECSWebSite/Support/TSSRequest.aspx?CategoryID=3&MenuID=19&LanID=0
2/5/2010 7:36:39 AM • Generic Memory... • Answered on Feb 05, 2010
My cables have been unplugged from panel two on a
If you look really close there might be a label next to the pins. other than that you need to go to the manufacturer's website for the manual.
1/18/2010 2:03:24 PM • Generic Memory... • Answered on Jan 18, 2010
Mac books have a key chain to remember passwords... do regular pc
if you are talking about websites, then using firefox allows you to remember passwords( via tools --> options --> then security; saved passwords)
whenever you go to a website and enter in a password, it will ask if you want to add, then on top of that you can enable a master password to protect that information from showing when you immediately access the particular site.
1/5/2010 4:32:18 AM • Generic Memory... • Answered on Jan 05, 2010
Error 25099 unzipping core files failed i was
Make sure that you remove all previous instances of Java on the system and start the process again as the compressed Java file has an error. If the process fails again after you have removed allinstances of Java from your system then try downloading and saving the file instead of installing dynamically via the internet. Then run the installation. This should work OK.
12/9/2009 3:02:55 PM • Generic Memory... • Answered on Dec 09, 2009
In my computer audio drive is not working
You say your audio drive--I don't know what you mean by that. I assume your sound card (whether it's part of the motherboard or a separate card) is not working.
In this case, I would first check to see if your sound has actually been turned off. Check on sounds in the control panel.
If you try to play system sounds from within the control panel and the little right arrow that you click to test stays gray, then you need to reinstall the sound drivers. Get them from the manufacturer of the computer or the motherboard manufacturer.
11/26/2009 5:47:49 PM • Generic Memory... • Answered on Nov 26, 2009
Cyberlink Power DVD error code 80040154 every time
from what ive gathered doin a bit of research is that you simply have to update power dvd this website has everything u need http://www.cyberlink.com/multi/download/patches_1_en_US.html
11/18/2009 9:04:37 AM • Generic Memory... • Answered on Nov 18, 2009
Computer DVD &DVD writer wont play can you
You need a replacement DVD player or you can get a DVD RW (Readable Writable).
You can find them very cheap on ebay but I recommand you go to a store and purchase one.
Thanks for using FixYa
Have A Nice Day
11/5/2009 3:18:11 PM • Generic Memory... • Answered on Nov 05, 2009
WHAT IS THE SPEED OF THIS PNY 64AOTFTHE-HS MEMORY
This is a PC2-5300 module, which is DDR2 667MHz.
Thanks for using Fixya.
10/27/2009 7:10:14 AM • Generic Memory... • Answered on Oct 27, 2009
How to install memory upgrades on GATEWAY GT 5042B PC
CLICK HERE. to get all the information you need about your computer.
Memory:-
  • Installed: 512 MB DDR2 533 MHz (PC4200) SDRAM
  • Expandable to: 4 GB (4 DDR2 slots)
  • If you want to know how do i install it? CLICK HERE.
    please rate my solution very high, if this infornmation is helpful.
    9/23/2009 2:26:11 PM • Generic Memory... • Answered on Sep 23, 2009
    How to store files onto my external hard drive
    saya punya hd maxtor 30gb pada posisi jumper master g bisa dideteksi bios,tapi pada posisi slave terdeteksi 41 gb.yang jadi masalah hd tersebut g bisa diinstal ulang atau diformat! mohon bantuannya agar hd saya bisa dipakai lagi.thanks
    9/6/2009 3:07:10 PM • Generic Memory... • Answered on Sep 06, 2009
    Computers & Internet Logo
    3 questions posted
    Top Generic Memory Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Generic Memory Computer and Internet Expert? Answer questions, earn points and help others
    View Most Popular
    • Generic Memory Computers & Internet
    Most Popular Question
    am trying fix retractable mouse
    • Computers & Internet
