20 Most Recent Gigabyte GA-7VA Motherboard Questions & Answers
I'have 2 socket a motherboard,
new coin step to bios hot key] see defaults there set time and date set boot order to HDD0 top off list) save exit bios, cold boot win. or put in coin cell backwards,? or used coin cells fail sure they do below 2.9vdc. sure.
6/4/2022 3:21:03 PM • Gigabyte GA-7VA... • Answered on Jun 04, 2022
Get format drive when plug in storage devices to USB ports
We hope you updated to Win 7.
3/29/2014 4:13:25 PM • Gigabyte GA-7VA... • Answered on Mar 29, 2014
2answers
Bios update
if you can use another pc and reinstall the previous bios flash it from floppy this should sort out the problem
or you can try and flash the updated one again if this fails
then you need to contact the manufacturer for a possible bios chip replacement
hope this helps !
7/29/2012 12:46:50 PM • Gigabyte GA-7VA... • Answered on Jul 29, 2012
When I turn on by pressing the power switch, the
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ? hope this helps
1/10/2011 4:01:19 PM • Gigabyte GA-7VA... • Answered on Jan 10, 2011
2answers
Video controller and webcam doesnt work
Uninstall the device from device manager.
Get the latest driver for the product from the particular website.
Connect the hardware now.
Install the drivers for that particular harware.
It will work perfectly then.
Follow the above for both the products errors.
6/30/2010 12:47:39 PM • Gigabyte GA-7VA... • Answered on Jun 30, 2010
My pc shows yellow color in device manager pci
first of all right click on the yellow shield you will get a pop out menu choose update driver if that not help then you have to reinstall your hardware
5/14/2010 9:54:34 PM • Gigabyte GA-7VA... • Answered on May 14, 2010
What's the best hard drive
Currently the Western Digital VelociRaptor is the fastest SATA 3.0 hard drive on the market. They are only available in 150GB and 300GB.
I recommend www.newegg.com and ship Fed Ex (UPS drops things)
The only way to make them faster is to use RAID0 which is not worth the risk because if one disk fails you lose everything. Any other form of RAID would actually be slower than a single disk. (See: http://en.wikipedia.org/wiki/RAID)
However, using multiple disks and assigning each a task will also improve performance. For example, install Windows on one disk and install all of your programs and data on another disk.
The latest trend is Solid State Disks (SSD). They are like USB flash drives designed to work the same as an IDE or SATA hard drive. They are still very new and expensive. They have a wide variation in performance and power consumption and they aren't all measured to the same standards. Personally, I would give these another year or two to stabilize and become mainstream.
Here is an excellent benchmarking website that has always helped me find the best of everything: www.tomshardware.com
I hope this helps.
3/2/2010 8:46:59 AM • Gigabyte GA-7VA... • Answered on Mar 02, 2010
Whats the most memory and hard drive I can use
For your hard drive it would require an IDE hard drive for that model motherboard.
  • 2 x UDMA ATA133/100/66 Bus Master IDE ports
  • As far as the memory
    1. Type : DDR333 (PC2700) / DDR266 (PC2100) / DDR200 (PC1600) -184pin
    2. Max capacity : Up to 3GB by 3 DIMM slots
    so that is 1gb each.
    Thank you,
    Lee
    3/2/2010 2:14:58 AM • Gigabyte GA-7VA... • Answered on Mar 02, 2010
    Missing motherboard interupt. CPU running 100%
    Most likely you've got a virus or spyware hogging up CPU cycles. Get a good anti-virus/anti-spyware program like Norton/Symantec or Kaspersky and do a full system scan to eliminate viruses and spyware.
    1/1/2010 5:51:44 PM • Gigabyte GA-7VA... • Answered on Jan 01, 2010
    Motherboard Simple PCI Communications Driver Code 28 for modem
    Hello, Mike.
    In case you still need this:
    To find and install the driver for the simple communications controller:
    Go to Device Manager and click on the pci simple communications controller
    Go to Properties and then Details. You will see a code like PCI/VEN_8086&DEV_27D8&SUBSYS...
    The VEN code means vendor and the DEV code means device: in the example the vendor is 8086 and the device is 27D8.
    Once you have the two codes, go to www.pcidatabse.com. Enter the two codes and you should get the name of your hardware.
    From there, you can search for a driver download for your hardware.
    Hope this helps.
    12/31/2009 8:44:54 PM • Gigabyte GA-7VA... • Answered on Dec 31, 2009
    Unfortunately i pulled out the panel switches from
    Go to this site and download the manual. then go to page 23.
    9/24/2009 9:02:51 PM • Gigabyte GA-7VA... • Answered on Sep 24, 2009
    Pci communication controller for gatway
    hey, check out this site and chose the best to download
    http://wareseeker.com/free-communications-controller/
    thank u
    5/14/2009 12:55:13 PM • Gigabyte GA-7VA... • Answered on May 14, 2009
    System won't budge
    Sounds like a power on/power good signal fault. Could be the power supply or the mobo. The voltages can be read at the ATX connector: http://www.formfactors.org/developer\specs\ATX12V_1_3dg.pdf or you can try another if you have a spare power supply to verify whether it is a mobo problem or power supply. Also there are power supply testers but they cost almost as much as an inexpensive power supply. It's an easy replacement task. Steve Medley
    11/16/2008 3:43:12 PM • Gigabyte GA-7VA... • Answered on Nov 16, 2008
    4answers
    I dont able to format my pen drive when i open it
    Hi
    First u attach your pendrive with pc after that u do a right click on pen drive folder ,then u click on scan option then the scan folder will apper and u select the pen drive folder by adding ,then click on next opyion and wait untill the scan is over .After scan over's then u can format your pendrive....
    Thanks for using fixiya
    Rupesh Kumar
    12/18/2023 12:36:15 PM • Gigabyte... • Answered on Dec 18, 2023
    Why my Gigabyte GA945GCM-S2C board GPU heat instantly
    If it is not an accumulation of dust and if your fans are working properly and your ventilation is not blocked, that there was not a built-in cooling system for this integrated part makes me wonder what is going on. One would have thought it suggested such was not necessary. How old is the thermal paste in the computer? I would replace that before trying more desperate measures. Rather than presume the fan was working, I'd make sure that it was. Here are some causes and fixes: https://www.onecomputerguy.com/gpu-overheating/
    10/15/2023 4:39:50 PM • Gigabyte... • Answered on Oct 15, 2023
    Hey, I own gigabyte W566N
    1/5/2023 3:23:38 AM • Gigabyte... • Answered on Jan 05, 2023
    Ati radeon hd 7770 problem
    no PC told at all no OS told either. sure a DESKTOP sure. no monitor told nor cable used, VGA, DVI,hdmi, DP i can not see your near black screen at all. cold booted is the PC splash screen dead./? all bios screen dead and all BIOS works even with HDD missing. idle black is sleep mode, a USA law mandates that. iof we do not like sleep mode we disable it in power settings CP CP means control panel this must be your first PC ever? and all go to sleep ,go to walmart see them all in sleep mode now, yes, a USA law called Energy star laws. and all wake up on demand new , unmolested. wiggling the mouse or hammering the space bar ends sleep but not if (again) power settings has USB going to sleep too. why post lacking Pc makers name and OS.windows what gee vast persons on earth ugraded w7 top 10 and now this fails. due to , PC maker told you , no w10 support in this secret PC 4 decades of 100,000 models of PC I can no no guess blind./ Radeon hd 7770 card and 80watt card in fact, oops.????? is this real ATI/AMD card or any of the other 12 makers of cards. ??????????? no full card number told and guess what the watts matter. 250watts is smallest watt PSU, or more if PC is loaded out like mine with 2SSD and 4 SSD and 1DVD and 1 Blue ray and max ddr and more. Power is first after fit, and yours fits so power is next PSU watts and what the card needs let me see that. all hits on this card show it crosses the magic 75watt rule for PCi-2 power of 75watts, and card is 80watts and more dynamically so they maker of the card has a 6 pin 12vdc aux jack that can not be ignored or the card fails, so is that wired up? as it must? yup top rear of card 6 pin aux power in black , steathy that, hard to see at 1st glance but 80watt cards need it, that and even 300watts cards are sold. does your card have red fan. see what I mean buy 12 maker of cars all with AMD GPU. the cards all have tag called the SKU tag or full model told for GPU speed and vram sizes and more, lots more. https://search.brave.com/images?q=%20Radeon%20hd%207770%20card# I have boxes full of old GPU cards here, stored. some need 500watt more PSU to even begin any 3d mode. only the SKU matters, wiki SKU. and what PC this is and what PSU wattage and if said PSU has the 2 AUX CABLES WITH DUAL 6/8 Plugs, (PCI-12v) marked. if not we can do adapters easy. ask
    6/4/2022 4:14:14 PM • Gigabyte... • Answered on Jun 04, 2022
    My soundcard is not working while using 8vm533m-rz model gigabyte mother board in windows 7
    so the PC mobo has and addin, PCI card sound"? 2004 PC mobo relic, now and 13yo to you. no card told. (fail)(buy only w7 allowed card if must) you did say CARD so means NOT ON-BOARD sound chip. relic P4 PC. mobo v1.0 mobo? this trash mobo uses EOL DOA, via chipsets, that do not allow w7 Integrated Realtek ALC662 audio CODEC chip this chip set is dead too, from maker realtek. if you knew that, and added a secret sound card. this mobo only does windows 200o to XP says so on page one at gigabytes this mobo. so w7 does not belong hear unless replacing every thing there that fails 1 by 1, , pain. ive done this vast times, for folks willing to. last xp driver is here for realtek https://www.gigabyte.com/Motherboard/8VM533M-RZ-rev-10/support#support-dl-driver as a rule only this OEM maker PC can make there sound chips work (as a team of parts) not simple as many think, even has mixer chips and more, all custom to maker. yes cards work better, on this mobo the VIA chip and codec chip must work or sound will be dead. and is common this. lacking no vista driver up, ever/ this mobo has no SATA ports nor any PCI express card slots at all. and finding PCI (non express) cards that can run w7 can be hard. for sure now. yes possible, with careful searching specs of relic PCI cards. also the VIA chip dead makes The ethernet port dead too. and usb dead and IDE drives dead,vista up. never buy VIA chipped mobo. or pain is all there is. no drivers.
    6/4/2022 2:16:57 PM • Gigabyte... • Answered on Jun 04, 2022
    Gigabyte GA-7VA Motherboard Logo
    21 questions posted
    Top Gigabyte Computers & Internet Experts
    MegaByteMe
    MegaByteMe
    Grand Canyon Tech
    Grand Canyon Tech
    SmartAviator
    SmartAviator
    Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
    View Most Popular
    • Gigabyte Computers & Internet
    Most Popular Question
    get format drive when plug in storage
    • Computers & Internet
