20 Most Recent
Gigabyte 7VM400M-RZ (GA-7VM400M-RZ) Motherboard Questions & Answers
Dvd player
hi , can u be specific, do u mean the DVD rom or the DVD software player to run dvd's???let know
6/3/2022 12:07:50 PM •
Gigabyte...
Answered
on Jun 03, 2022
Had 512mb ram installed in each slot and one day
Your motherboard is quite old. It could be the RAM slot is simply dirty(use canned air), but if that's the case, the PC doesn't boot. The memory controller could be dying(replace motherboard or upgrade system). There could be other issues but it sounds like your memory itself is fine.
You could try reinstalling the BIOS, but because of the age of your computer, you shouldn't spend any money trying to get it fixed. It would probably be cheaper just to get a compatible used motherboard on eBay as replacement. The better long term financial decision would have to be building either a used parts PC (because CPUs have barely gotten better in the last 5 years) or a brand new system.
This isn't very much information to draw on, so if you can update your information, I can help more.
10/24/2017 5:11:22 PM •
Gigabyte...
Answered
on Oct 24, 2017
Hello Sir, When SMPS for motherboard burnt, all
Get a good used mo bo on ebay to replace the one you have.
Make sure you get the exact replacement and it will go right in and you will not have any hassles with compatibility/driver issues.
Lot cheaper!!!!!!!!!!!!!!!!
3/21/2017 3:34:21 PM •
Gigabyte...
Answered
on Mar 21, 2017
The computer won't start up
does the computer put anything on the screen?
does the computer one beep after self test?
what kind of lights or no power at all
any errors. windows boot up problems
7/17/2015 8:53:25 PM •
Gigabyte...
Answered
on Jul 17, 2015
The AC97 on Motherboards after new Windows
You should say what version of Windows. The AC97 chipset is so common that it must be supported. Many Windows XP drivers will work for Windows 7. You must unpack the driver files and select it manually from device manager.
10/29/2013 12:14:32 PM •
Gigabyte...
Answered
on Oct 29, 2013
My problems is sound driver download
first you check sound is mute or not if the complaint is still there then goes to my computer-> properties->device manager-> hardware, if a question mark in the sound driver then u can download it from company site before downloading sound driver you have to verify your laptop model number & model name then then type it in the site(service & maintains section) after download you can instal it in the computer by click RUN-> next-> finish, through this way you can solve the problem
10/1/2012 6:38:41 AM •
Gigabyte...
Answered
on Oct 01, 2012
When powerd up i get 1 long beep after another,what could it bve?
Each motherboard BIOS has a series of beeps meaning different things. If you are getting two long beeps then I recommend looking up in the pdf manual in the FAQ or troubleshooting section of the guide. It could be anything like a heatsink not properly inserted, or the cpu cooler fan is broken or not plugged in, the memory needs reseated, or graphics card is not compatible, etc.
1/2/2012 10:56:32 AM •
Gigabyte...
Answered
on Jan 02, 2012
in my computer properties,it
This is Gigabyte Support > 7VM400M-RZ motherboard > Main support page,
http://tw2005.giga-byte.com/Motherboard/Products/Products_Spec_7VM400M-RZ.htmIn the small chart in the middle where it states, Overview, Awards, BIOS, Comparison Sheet, CPU Support List Driver, FAQ, Manual, and News, click on > Driver.
(AMD Sempron 2400+
That fits in a Socket A processor socket. Socket A is also known as Socket 462.
Click on Manual for the motherboard manual)
11/24/2010 8:09:19 PM •
Gigabyte...
Answered
on Nov 24, 2010
I am having a Problem
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps
10/18/2010 11:01:11 PM •
Gigabyte...
Answered
on Oct 18, 2010
