20 Most Recent
Case Logic EW-609 3-Button Wireless Rechargeable Optical Scroll Mouse Questions & Answers
Logik wireless mouse
1. Make sure the mouse is fully charged. The underside should have a red flickering light if it is working properly. If not you need to change the batteries.
2. Plug the USB dongle into the computer. The blue light should light up and flash rapidly as you move the mouse around. If it still doesn't work you need to re-sync the mouse with the dongle.
Turn the mouse off and back on again. Hold it near the USB dongle.
Push the blue button on the dongle. It should flash steadily. Push the reset button on the bottom of the mouse. The blue light on the dongle should start flashing rapidly and your mouse should now work.
How to pair my wireles case logic keyboard with my tv
Hello Sheatha, a few information doesn't help, but the first thing you should know if both are compatible with each other; Do you have a Wifi adapter that allows you to connect to this keyboard? I don't think it is objective to pair a keyboard to TV or SmartTv.
How to connect a bluetooth mouse to a computer
Use your Computer to search for Bluetooth devices. How to search depends up on the version of Windows you have on your computer. After searching, if your computer finds your bluetooth mouse, then you select it and select connect.
I've shown you (in the pic attached) how to go about this process on my computer.
This mouse worked fine for several weeks. But
Mice and keyboards only last so long. Some are better than others; however, its time to get a new one. I suggest you put up about $30 and get a Mouse/Keyboard Wireless set. No wires and no fuss.
Mouse driver
so download it and install it...... go to manufacturers web page, or installation CD, or let Windows find driver automatically
My case logic optical mouse will not link up
Is this a wired or wireless mouse?
If this is a wired mouse, try connecting it into different USB port or different computer so that you would know if there's a problem with the USB ports or with the computer or with the mouse.
If this is wireless, try the following:
1. Replace the batteries of the mouse.
2. Make sure that the mouse is turned ON.
3. Try connecting the USB wireless adapter of the mouse into different USB ports.
4. Connect also the adapter into different computer.
5. Make sure that there's no interference between the adapter and the mouse such as wireless phones, cell phones and other wireless devices.
Wireless mouse, cordless phones and cellphones are all running at 2.4Ghz frequency, so if there's a wireless device that's running on the same wireless freq, then it would interfere with the mouse that would cause the mouse not to work.
If same problem occurs after checking everything, then contact the manufacturer of the mouse for RMA (repair).
Have a great day!
My case logic mouse does
I tried searching case logic's site for support for this mouse...but to no avail. Apparently this was a hit and run product they never looked back on. Anyways, I found a few answers from other users on the net. Here's one such solution I could glean. Hope it helps:
1) Locate the 'reset' button on the bottom of the mouse. (Tiny little black button on ours...)
2) Plug in the USB receiver. The blue LED button should light steadily.
3) Turn on the mouse. Hold it near the USB receiver.
4) Push the blue LED button on the receiver, and as it begins flashing slowly, push the reset button on the bottom of the mouse. This should synchronize the mouse and the USB receiver within moments.
5) If the blue LED button on the USB receiver begins flashing very rapidly, the mouse and the USB receiver are communicating, and the mouse should begin to work.
If it does not, the battery in the mouse may need to be removed and replaced, then the whole process started again...
If it works, you'll probably have to go into Mouse Properties in your Device Manager and adjust the response of the mouse, because the default settings are often positively crazy sensitive!
