20 Most Recent
Sony Ericsson Sony Xperia S Lt26i Quad 12mp Hspda Gps 32gb Black Phone Questions & Answers
Sony Ericson 250i Headset not recognised
The wire to headsets can get damaged (usually not visible from the outside, as the wires inside the covering can be very delicate, to keep the size of the wire down) from throwing them in the pocket, purse, etc. Try a set from a friend to make sure the device is still working itself.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
