20 Most Recent
3Com OfficeConnect VPN Firewall - Firewall - 4 ports - 253 Connections - EN, Fast EN, English (662705471105) Questions & Answers
Remote access for 3com firewall network
dial in using the vpn to the windows 2003 server network and call the remote desktopof the server using the netbios name or using the local ip address
8/18/2009 10:00:38 PM •
3Com...
Answered
on Aug 18, 2009
Suddenly Disconnected
maybe it's overheating ?! see if it is too hot, and if so, try to coolit (with a fan for example) and see if that is the cause ...
(i don;t know u;re product, but overheating is a general problem ...)
7/3/2008 1:02:44 PM •
3Com...
Answered
on Jul 03, 2008
I have AVI Video and it only plays sound
Ok it is may be do you to system is old needs up to date , so that the video may not have downloaded completely from the source web portal. The media player present in your handset is outdated.
Db9 rj45 pinout
Here is the standard pinout for a console port on a router to seriel port for computers
HI,
I have two 3com
I don't know anything about these units, nor do I have time to source any docs for you, but maybe you can try connecting a PC directly to the port your patch panel is connecting the the switch from, you can at least see if that port is working.
My next and only other suggestion is to invest in a "LAN cable tester". In my area, you can find cheap ones for U$20.
The tester will allow you to check connectivity between any two ports, and allows you to test both patch links and individual CAT5/6 cables.
Facebook recovery
notify the police dept / person handling the case and let them know about the face book information
