20 Most Recent
3Com SuperStack 3 4400 (3C17204-US) 48x10/100 Mbps Networking Switch Questions & Answers
Fiber module
you can login though the console cable, switch back side conso;e port will be there, it will bw like RJ 45 port
Problem with SW 4400 - restarting....
switch dont restart by themselves without command, first remove the switch from the network, disconnect from internet, make sure you hadn't fired anybody recently it sounds like a hack. reduce network traffic to local area only and priortise important internet traffic. now got back to the switch and troubleshoot make to check the reboot command on error or when error is found, if the problem stops when the switch is remove somebody is messing with the network.or the darn switch is faulty install a new one.
How to check if the switch is manage or unmanaged
Managed switches you can enter the default ip into a web browser, login and "manage" settings" this default IP will be vendor specific. Unmanaged you just plug in devices and that's about it. Managed switches you will pay a lot more for. Some lower end ones maybe several hundred dollars and up. If you are buying switches at Best Buy they are almost all unmanaged.
I have AVI Video and it only plays sound
Ok it is may be do you to system is old needs up to date , so that the video may not have downloaded completely from the source web portal. The media player present in your handset is outdated.
Db9 rj45 pinout
Here is the standard pinout for a console port on a router to seriel port for computers
HI,
I have two 3com
I don't know anything about these units, nor do I have time to source any docs for you, but maybe you can try connecting a PC directly to the port your patch panel is connecting the the switch from, you can at least see if that port is working.
My next and only other suggestion is to invest in a "LAN cable tester". In my area, you can find cheap ones for U$20.
The tester will allow you to check connectivity between any two ports, and allows you to test both patch links and individual CAT5/6 cables.
Facebook recovery
notify the police dept / person handling the case and let them know about the face book information
