Find your computer's IP address :
Windows 7, Vista, and XP, using the command prompt
- Click Start, and then select All Programs.
Note: If this doesn't match what you see, refer to About navigation settings in Windows.
- Click Accessories, and then Command Prompt.
- At the command prompt, enter: ipconfig
The IP address (or IPv4 address, if you are using Windows 7 or Vista) will be a series of numbers following the pattern xxx.xxx.xxx.xxx (i.e., 156.56.27.32).
Note: If you are using PPP with a modem at home, your IP address will change each time you log in.
Windows 7, without using the command prompt
- In the system tray, click the network connection icon and select Open Network and Sharing Center.
- To view the IP address of a wired connection, click Local Area Connection.
To view the IP address of a wireless adapter, click Wireless Network Connection (Network Name).
- Click Details... . Your IP address will appear next to "IPv4 Address".
Windows Vista, without using the command prompt
- From the Start menu, right-click Network, and then select Properties. This opens the Network and Sharing Center.
- To view the IP address of a wired connection, click View Status to the right of Local Area Connection.
To view the IP address of a wireless adapter, click View Status to the right of Wireless Network Connection.
- Click Details... . Look for the address next to "IPv4 IP Address".
Windows XP, without using the command prompt
- From the Start menu, right-click My Network Places, and then click Properties.
- To view the IP address of a wired connection, double-click Local Area Connection.
To view the IP address of a wireless adapter, double-click Wireless Network Connection.
- Click the Support tab, and then click Details... . The window that appears will display the IP address.
Your IP address has to be in the 192.168.123.xxx range
The router must be configured to match your
Internet service. If you do not know your
Internet connection configuration, please
contact your Internet Service Provider (ISP).
By default, the router is pre-configured with
these settings:
• Automatically set IP addresses for
computers on your LAN (connected to the
router's ports 1-4). The router acts as a
server for dynamic host configuration
protocol (DHCP) and assigns IP addresses
in the range 192.168.123.100 through
192.168.123.199
• The default LAN IP address for the router is
192.168.123.254 with a subnet mask of
255.255.255.0
• The Internet service connected to the
router's WAN port uses a dynamic IP
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
