20 Most Recent
Logitech Extreme 3D Pro Joystick Questions & Answers
My logitech extreme 3d
Hi Mertmercanka, try setting the 'joystick deadzone' to a higher setting. This is a setting that is usually located under
options -> controls.
How do I program the buttons on my Logitech 3D joystick to be the same as keyboard controls
Normally with most games there is a setting under options -> controls called 'keybindings' that you can see what your keyboard keys are assigned to. If the game registers that you have your joystick plugged in, you should be able to then click one of the key assignments and then move the part of the joystick you want to be assigned to that control. (eg. if you want to assign something like 'throttle up' to the rotating knob, you click that control in the keybindings and then rotate the knob in the direction you want to use when playing)
Is Thrustmaster T Flight Hotas X joystick
Yes it is compatible with windows vista. It is a plug and play device and should install itself as soon as you plug it in without the need of installing drivers from the included cd.
Installation, and testing the Logitech Extreme 3D Pro Joystick
The joy stick comes with a CD. Put the CD on the tray, and let the computer runs the software. On the CD there are driver for the joy stick itself, and driver for the USB . click on install joystick, after that, click on install the USB drive. that is it. Then a test screen will appear and asks you to check your joystick movements and buttons .push on the buttons,on the joystick, and you will see that they turn red on the computer screen each time you push a button, meaning your computer reads the commands from the joystick, You are set.
If you do not have the CD, then go to the Logitech site. and go to support, and from there you can download the drivers for the joystick.
Throttle
Go to screen and make sure throttle position is in idle position..now move slider to full idle position...on the left hand side of the slider you will find a hex screw,,,,insert the correct size hex wrench and make sure you hold the slider firmly in place and tighten the hex screw...I had a similar problem and this is how I solved
[email protected]
Rudder doesn't remain centred
Meanwhile the solution is EASY.
I had the same problem after a year or so. Trying to steer to the right, no response. Couldn't get worse, so i had to buy a new one, that gave me the possibility to experiment. This is what i did, and it worked. Turn the stick up side down, remove the bottom plate, only that. Put it on your desk and lift the grey plate up. There you see the x and y axis roll-contacts (excuse my tech-english). These are the little black rectangular contacts, you can recognise them by the multicolor wiring atttached. Theres 2 of them, one for pushing forward/back, and one for pushing left/right. Now be carefull, and spray a LITTLE contact spray on the middle of this roll-contact. It will lubricate the contact,which has dried up during use/time. For me it worked like a charm, as NEW! Do NOT unscrew the stick itself, otherwise you have to puzzle a lot to assemble it again (believe me, you don't need it and don't like it). Screw the bottom plate back and enjoy the flight again for months.
