20 Most Recent Venta - Airwasher LW44 Air Purifier Questions & Answers
2answers
How can I make my own venta Airwasher Water Treatment?
I use white vinegar and hot water. I soak the disk for a few hours. It's amazing. My venta is 10 years old. I also use different scented oils in mine to fragrance the room. I use it daily. I got a new venta but like the older model better. It is my sleeping machine it provides a white noise that I sleep very well to. The new one is too quiet and seems more fragile.
8/28/2019 6:33:04 AM • Venta -... • Answered on Aug 28, 2019
Do you have to replace the filter each year at
no .. there is no replacable filter .. you do have to clean the housing and disk stack .. the motor assembly comes out easily so you can clean things ... kind of nice 10 warranty with that ... follow instructions for water ..
10/5/2009 8:12:17 PM • Venta -... • Answered on Oct 05, 2009
2answers
My Venta Airwasher LW44 motor won't start
Test the motor to see if it works. Make sure the motor is removed from the rest of the unit. To find out how to remove the unit please hit the "Go Back button and select the "How to remove the motor button"...
  1. Plug the unit in to a working outlet.
  2. Push the #1 speed button on top of the motor.
  3. You now need to engage the saftey switch to start the motor.
  4. Protruding from the motor are two plastic about 3-4 inch guiding arms.
  5. Look inside the end of both of these two guiding arms. One of the arms are hollow and the other one has a white safety switch in the arm.
  6. Use a pencil or small item to push in on the safety switch.
  7. If the fan sarts to rotate the motor is still working.
  8. If the fan does not rotate then the life of the motor has probably ended and a new motor is needed. ( insert motor part link)
For additional support email [email protected]
8/23/2009 4:27:58 AM • Venta -... • Answered on Aug 23, 2009
2answers
Clean fan area
NOTE:It is easier to remove the motor when the upper housing is still sitting on top of the lower housing unit.
  1. Turn the power off by unplugging the unit.
  2. Next to the speed directions buttons there are thumb tabs. Press the thumb tabs so that they pop up and unlock the upper housing flaps. a tumb tab on
  3. The four flaps should then drop down like the peddles of a flower.
  4. Grab the center of the motor and lift straight up, be careful when pulling the power chord.
  5. The motor, fan and gear assembly should not be seperated from the rest of the unit.
This will let you clean with vinegar and water.
Great product. Germany design at its best
8/23/2009 4:26:46 AM • Venta -... • Answered on Aug 23, 2009
2answers
Water doesn't evaporate
the problem is with the pump
try opening the humidifier and removing the hose clear the hose out...check all connections to the pump and see if the pad becomes wet.... the humidifier should still evap even if the room is humid.... let me know if i can do anything else.... feel free to e-mail me at [email protected]
8/23/2009 4:24:48 AM • Venta -... • Answered on Aug 23, 2009
2answers
Venta l44 motor won't run less than a yr. old
I own a 3-year old Venta L44 in which the motor stopped turning the wheels inside. It just sat there humming and eventually got hot. I sent an email to the Venta web site asking if they had a recycling program -- they don't. Instead, they replied (after a few days) stating that the motor was covered under the 10-year warranty. They sent me a new motor which was super easy to install. It didn't cost me a thing. It nows works perfectly.
8/23/2009 4:21:44 AM • Venta -... • Answered on Aug 23, 2009
Venta LW24 stack failure.
I have the same problem. Must be defective units. Have only had mine a couple of years.
11/1/2008 8:55:00 PM • Venta -... • Answered on Nov 01, 2008
0answers
Venta LW 44
Be the first to answer 9/28/2008 9:51:35 PM • Venta -... • Posted on Sep 28, 2008Be the first to answer
8answers
Motor runs but wheels don't turn
If you have used it for a long time then minerals in the water may have built up somewhere and now needs to be removed wither by cycling a cleaner of some sort or physically scrubbing the moving parts yourself.  The first ting to try is unplug the machine, remove all the filters, and try cleaning with vinegar. Smells bad I know but following up by cleaning with a regular detergent should remove the smell. Detergent alone will not break up the calcium, the acid in the vinegar does that. Next we need to find out what gears may have slipped or if there is a belt out of place. If everything mechanical is in working order then the cam from the motor to the rest of the unit may be shucked in which case it would depend on where it is broken to determine the best repair. Please, if you could as some problems like this are not always simple, take a look at your particular unit and provide me with some further description of what is going on.
6/2/2008 1:53:51 PM • Venta -... • Answered on Jun 02, 2008
Ionic Pro Platinum TA750 Air Purifier. It will not turn on?
Question edited for clarity and toss in some CAPS. Question moved from Televisions category. Contact their Support for a warranty repair. https://www.envion.com/en/ta750 ..
12/12/2023 5:16:43 AM • Air Purifiers • Answered on Dec 12, 2023
I have an Afloia Air Purifier. The red light keeps blinking?
Question edited for clarity, dreadful spelling and typos. :>D Question moved from Televisions to Air Purifiers. Your air filter is dirty and needs cleaning.
Afloia Air Purifier Blinking Red - Repair, Care and ...
https://plentifulair.com > afloia-air-purifier-blinking-red... A flashing red light in all Afloia air purifiers indicates that the air filter needs to be replaced. Typically, in these air purifiers, the red light turns on ... ‎Why is My Afloia Air Purifier... · ‎How to Replace the Air Filter in... ..
11/7/2023 2:12:50 PM • Air Purifiers • Answered on Nov 07, 2023
Lost remote can I download one or an app for it please.
Question edited for clarity. Question moved from Cars and Trucks. From the maker https://www.google.com/search?q=Fresh+Air+by+Ecoquest+replacement+remote ..
11/7/2023 5:38:27 AM • Air Purifiers • Answered on Nov 07, 2023
My 20w aspectek bug zapper has stopped working, both bulbs off
Turn off the power button and Unplug the bug zapper. Turn off and Unplug Discharge Bent down and Remove Rotate and Replace the bulbs
8/27/2023 12:59:29 PM • Air Purifiers • Answered on Aug 27, 2023
What can I do to troubleshoot fuse blowing each time I turn on sanitizer - Breeze AT by EcoQuest
breaker blows or internal fuse ----either way need a multi meter to test for short
6/20/2023 1:21:36 PM • Air Purifiers • Answered on Jun 20, 2023
Rainmate Air Purifier. Why does my Rainmate not mist?
Question edited for clarity and correct maker name, plus (what it is). Question moved from Cars and Trucks. Usually just need cleaning and descaling
Cleaning Tips
Rainbow System https://rainbowsystem.com > Support You can even fill the Sprayer with ordinary household water and use it to mist your houseplants or clean your screen windows.
The Rainbow Rainmate: Does It Really Work?
GroundWaterGovernance.org https://www.groundwatergovernance.org > does-the-ra... Mar 13, 2022 - The simplest solution appears to be to change the water on a regular basis if possible. A home air purifier can be used as an aromatherapy ...
6/8/2023 3:47:31 PM • Air Purifiers • Answered on Jun 08, 2023
Venta - Airwasher LW44 Air Purifier Logo
15 questions posted
Top Venta Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Venta Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
Venta Air Purifiers
  • Venta Air Purifiers
Most Popular Question
venta l44 motor run less yr old
  • Air Purifiers
