20 Most Recent
Samsung SGH-i717 Galaxy Note HD LTE 16GB Rogers Unlocked Black Questions & Answers
Galaxy Note slow charge. Holds battery well though.
try this ..get a qtip and dip in 99% rubbing alcohol. not too wet. just damp. clean contacts on the charger port. use a magnifying glass and light to check if its clean. let it dry for 20 mins. it will also help if you have airplane mode on but its optional. use oem charger and cable or ipad charger works fine with samsung cable. hope it helps
What are the apn settings for t mobile on unlocked i717
APN: epc.tmobile.com but you it's an LTE Device, use: fast.tmobile.com instead
Proxy: <Leave in Blank>
Port: <Leave in Blank>
Username: <Leave in Blank>
Password: <Leave in Blank>
Server: <Leave in Blank>
MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
MMS proxy: <Leave in Blank>
MMS port: <Leave in Blank>
MCC: 310
MNC: 260
Authentication type: <Leave in Blank>
APN type: default,supl,mms
APN Protocol: Leave it to the Default one
My i717 is stuck in headset mode
most likely you have the microswitch in the jack itself that is stuck or broken. Try pushing the headphone plug all the way in, and remiove it quickly a couple of times. If this does not work, you may need to bring it in for repair.
Samsung i717 no network
Everyone here seems to be addressing the memory card issue... which i think is the least of the problem... The sim is not being read, that's the major issue. One way of fixing this is by downloading Titanium Backup Pro and using the clear cache feature. Worked for me. Keep in mind that your phone has to be Rooted.
Cannot send sms
1.go to your message settings and check the message center number to see if it is correct2. call to your network operator customer care3. request the message center number...4.note it down5. go to message settings>message center number6. insert the number which is noted by you and save itthis solves your messaging problem ...Good luck
How to unbrick galaxy note i717
i make a mistake and download the wronge rom for my rooted galaxy note i717 now it not doing nothing and not even coming on to recovery what should i do?
