20 Most Recent
Element ELCHW402 40 in. LCD HDTV Questions & Answers
My Element 40" Tv is stuck in stand by how do I
hi have you changed the batteries in the remote, if the remote is ok there's a fault with the tv, could be a swollen capacitors shorted diode or poor solder joint,or a bad mainboard , thanks
shaun
Television was on and suddenly shut down and won't turn on now
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Why is screen flickering with horizontal lines?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Why won't my 40"flat screen tv come on?
Power on of key problem is main reason behind this problem. After plug in TV with power. Wait for 6 second and try from remote power on button. If full fail to power on please contact the expert lab engineer.
Why cant i get my digital channels
Is your TV designed for digital signals, if not you will need a set top box. Make sure the aerial is in good order and all connections are tight and clean , go into settings on the TV, select digital tuning and press ok , if the TV is in good condition and there is a signal digital to the aerial it will download
Flat screen
Use distilled water and a microfiber cloth for best results. If the screen is really dirty, use a diluted household cleaner, such as 409, either sprayed or sponged on, then dry with the microfiber cloth.
Why does my 40" element TV have sound, but no picture?
could be many issues. Take a flashlight and hold it right against the screen. Can you see a picture? if so the lcd is working but the backlights are not. If that is the case you could have bad power supply caps on the 24 volt section, a bad inverter board, or a bad ccfl lamp itself inside the back of the screen
The screen went black
LCD sets use either a fluorescent backlight or LEDs if newer. If your set uses the fluorescent type, either the lamp itself or the inverter that produces the 'strike' (high) voltage for it has failed.Inverter failures are pretty common but the lamp life in in 5-digits of hours (probably >10,000 hrs)
Dual image at start up
Yes, either a bad part that when cold is not working right or a bad connection that is doing the same.Based on description problem either in power supply or board that controls all digital processing in the set.
