20 Most Recent
Hannspree SN10T1 101 Tablet Questions & Answers
How do I adjust brightness on hannspree tablet
Go to Settings, Display, Brightness. If you have never accessed Settings, do a finger slide from the edge of the screen where you see the battery indicator symbol, and you should see an option for Settings (or a small symbol at top right that looks like a cog such as you see where the chain connects to the back wheel on a bike). Selecting/touching that will open the full Settings menu. Then scroll down until you see Display, touch that, and then find Brightness and touch that. Then you should see a slider. You should also see an option for Automatic brightness control. Some tablets come with this selected by default. Choosing it will cause the tablet to brighten when outdoors or in a brightly lit room, and to dim automatically when lighting is low. I have never liked it, but it works for a lot of people who are not as picky as me, and can potentially allow your battery to last longer. Good luck and enjoy your tablet!
Android System Recovery
Obvious question is what the tablet had been doing during its' last use.
Was something newly installed, was system or apps updated, etc. ?
Were all the APPs and or system shut down properly ?
Did update or installation recommend restarting system, prior to use ? Were multiple installations / updates performed ?
Your device appears to be in a recovery boot-loop.
As stupid as this may sound ...
Is the power adapter connected ? Let battery charge for at least 30 minutes and try again.
If battery is low, it may not complete the reset. - you should have seen something on the screen, denoting " wipe and reset " procedure and completion - prior to (#1) Rebooting device
Per your post, you have already (#4) wiped the data and instructed the device to reset to factory settings, then (#1) Reboot system.
That is the generally accepted reset method
This problem is not all that uncommon, it generally results when attempting reset, internal boot commands error for what ever reason. ( can not find the factory restore / recovery file set ).
This problem is more common when "fixes ", Specialty " Roots " or "mods" have been installed by the user - making changes to the boot program and commands OR when manufacturer files have been deleted / moved from system access. - Common suggestion is to work backwards through the mod processes and / or attempt to re-install mod or follow the special mod recovery method.
Without having available the proper ROM " flash " update / installation file(s), and you may " brick " the device.
I recommend you go to manufacturer site and check for available ROM files, reset / reinstallation processes ( memory card method ? )
You state the tablet is less than six months old. You may want to contact manufacturer for possible warranty service.
They will most likely ask the referenced obvious questions, to better understand the cause / nature of the device failure and recommend the best immediate possible solution.
This may not be what you seek, I hope it will provide better direction.
I have a hannspree SN1AT71WEE301 i cannot connect to the camera is there an easy fix.
Assuming the built in cameras are the issue,
\are you using the provided software ?
You can try to update the ROM and / or drivers for those devices.
sometimes an update may not install properly and re-updating the ROM and / or specific device drivers would solve the issue
Attached is a link for the English device manual:
http://www.hannspree.eu/uploads/Downloads/TabletPC/UM/SN1AT71/SN1AT71_User-s_Manual_EN.pdf
If you are having difficulties with the device recognizing an attached camera device, you may need to go to camera device manufacturer website and download the appropriate drivers to match your tablet device operating system and connection type.
Ex: USB driver for camera connecting using a usb port connection. Also ... confirm proper cable is being used.
Ex: Some connections require 5 contact point cables, others only 4 contacts - this will be determined by your devices.
I hope this was helpful.
I have a hannspree sn1at71 bee301
Sounds like a boot loader failure
1. Power off the device. (Make sure to plug in AC power.)
2. Press and hold Volume Up(+) button and Power button at the same time for 5 seconds, and release both buttons to enter system recovery utility.
3. Press Volume button to select " wipe data / factory reset " and press Power button to execute
4. Press Volume button to select " Reboot System Now "and press Power button to execute
Hannspree Customer Service at:888 808 6789 (1-909-992-5025 outside of the US); Mon - Fri: 6am - 6pm PST / PDT.
Cannot connect camera error
Mine has stopped working as well. I did as restore, deleting everything. Don't bother. It didn't fix it. I am calling Hannspree today and will post here if there is a solution,
Reset button
1. Go to settings
2. Scroll down to Backup & Reset.
3.Go to Personal Data
4. Choose Factory data reset.
Be aware that you will lose all unsaved settings. I've tried doing it numerous times to try to get the non working camera to reset and also to get the G-sensor to work. Not fixed doing this.
Wont load past android logo
Give it about 2-5 minutes , if that doesn't work try holding the power and volume button until it shows you a reboot option.
