20 Most Recent Olympus P 400 Thermal Printer Questions & Answers
2answers
Olympus P 400 driver mac 10.84
Olympus has not supported that printer on the Mac in 10+ years. Also checking the Apple printer driver support page I do not see ANY Olympus printers currently supported by Apple: OS Printer and scanner software available for download I would suggest replacing that printer with a current model photo printer (also Dye-Sub) from Canon. The Canon Selphy Dye-Sub photo printers produce flawless professional glossy prints: Compact Photo Printers
8/6/2020 12:13:33 PM • Olympus P 400... • Answered on Aug 06, 2020
Need driver for olympus p-400
Currently there's no windows 7 drivers for this model, but we can still run this printer by installing the xp drivers in "Compatibility" mode. If you don't have the Xp drivers, download it from the link below and follow the instructions;
Olympus p-400 windows xp drivers
As soon as you click the link, download will automatically begin, you'll need winzip or winrar program to unzip the files. Extract the drivers to a new folder, right-click on the Setup file, click "compatibility" tab and check/tick "Run this program in compatibility mode for" and select "Windows XP (service pack 2)", click "Ok", Now run the "setup" and connect the printer when you are asked to do so. This will definitely fix your problem. Many drivers and softwares which aren't compatible with windows 7 can be installed and run in the same way.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
2/22/2020 7:27:10 PM • Olympus P 400... • Answered on Feb 22, 2020
The colors print misaligned, the blue and yellow
Had the same problem. The colours were mis aligned, or out of register. Tried everything, but nothing worked. Was going to toss it out, then tried changing the paper size in the print setup window of Photoshop to A4. Just make sure whatever Photo program you are printing from to choose A4 as the paper size. Printer worked fine after I did this.
3/21/2014 4:35:46 PM • Olympus P 400... • Answered on Mar 21, 2014
0answers
I'm looking for a driver for my Olympus P-400 for os x
There's none. Turns out the printer is unsupported in Leopard and above. Gutenberg driver doesn't work, either. Olympus support says to throw out the printer.
10/15/2013 4:48:05 PM • Olympus P 400... • Answered on Oct 15, 2013
3answers
I need a 64 bit
This is an old model , the only Windows drivers that Olympus made for it are for XP and 2000 at 32 bit - there isn't any for 64 bit on any form of Windows.
9/13/2011 11:23:37 PM • Olympus P 400... • Answered on Sep 13, 2011
Ik heb de printer driver nodig voor olympus P400
Only support for Downloads Available: w.gif P-400 driver for Windows 2000/XP Olympus printer driver for Windows 2000/XP.
(self-extracting .exe file - 1.0MB) (6/02)
w.gif P-400 driver for Windows 98/Me/NT Olympus printer driver for Windows 98/ME/NT. (self-extracting .exe file - 1.5MB) (12/00)
1/12/2011 2:46:58 PM • Olympus P 400... • Answered on Jan 12, 2011
Unable to load software on my new Mac. Says no
There is nothing you can do about that software, the producers probably dropped support for the mac. The only thing you can do right now is use an open source driver. just google up "open source printer drivers mac" I think there should be a open source driver for it. I'm pretty sure it will support your printer to get it up and working. However you might find that some of the features are missing. If you really really like the software, then you should just use it with another computer, like a pc.
11/30/2010 3:46:50 PM • Olympus P 400... • Answered on Nov 30, 2010
0answers
I need a driver for
olympus discontinued their printer a few years ago, there is 64 bit driver available for it.
9/3/2010 5:05:41 AM • Olympus P 400... • Answered on Sep 03, 2010
Need printer driver for windows-7 for olympus
Non available for your model for Windows 7
Checked by the link below for reference
http://www.google.com/search?client=ubuntu&channel=fs&q=printer+driver+for+windows-7+for+olympus+p-400&ie=utf-8&oe=utf-8
8/12/2010 2:47:43 AM • Olympus P 400... • Answered on Aug 12, 2010
2answers
hi: look on site olympusamerica.com
11/1/2009 1:03:39 PM • Olympus P 400... • Answered on Nov 01, 2009
2answers
Error 301b(1805) for olympus p400 printer
The driver for the P-400 printer will work in Windows Vista. To install it you will need to install it in Windows compatibility mode XP service pack 2. Download the P-400 driver to your desktop from the Olympus website. Open the zip file, right click the mouse on the setup.exe file then left click on Properties. There will be a compatibility tab there. Select XP Service pack 2 and then click Ok. Connect the printer to the computer and direct the found new hardware wizard to the folder for the files it needs to load the device driver for the printer. If this does not work, you may want to call Olympus Tech support for assistance. Their telephone number is 888-553-4448.
6/14/2009 2:15:08 PM • Olympus P 400... • Answered on Jun 14, 2009
LCD Display on HP C5180 printer stopped working.
sorry but the display is probably still covered in puke inside. you will need to replace the whole display. or take it apart and clean it check that everything is ok and put it back in.
12/29/2008 9:23:29 PM • Olympus P 400... • Answered on Dec 29, 2008
Olympus P 400 Thermal Printer Logo
29 questions posted
Top Olympus Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Olympus Office Equipment & Supplies
Most Popular Question
looking driver olympus p 400
  • Office Equipment & Supplies
