20 Most Recent
Playtex Diaper Genie II Elite Diaper Disposal System Questions & Answers
Guide how to properly clean a dirty fan that overheats in acer aspire notebook
Remove the fan from laptop, and remove the dust build up from the fan blades. Next remove outer cover of fan and clean inner section of fan case. Reattach outer cover of fan case. Next clean surrounding area in laptop and than re insert fan in laptop.
Unless you know how to take a laptop apart and put it together again, I do not recommend trying this.
As for the Playtex Diaper Disposal gene problem I need more information on the problem before I can help with that one.
The mechanism inside my diaper genie II fell
There are two parts to the diaper genie clamp mechanism. Look closely at the cutaway view of the diaper genie at this link: http://playtexbaby.com/App_Themes/PlaytexBaby/pdfs/DiaperGenieIIAdvanced_OwnersGuide.pdf One part that has the cutter, and one part has the spring attached to it. If you look closely at the illustration where it is labelled "clamp" and follow the black line it actually points to the spring - its just such a poor quality image you might miss that detail. Look at the orientation of the parts to each other in that illustration so you know which direction the parts go. To reassemble, starting with the part that has the cutter built into it, slip the end of that part that is opposite the cutter under the spring on the second part. When assembled, the smaller part of the clamp slides upon the other part, and when the clamp,is pulled apart the spring tension pulls the two parts back together. These two parts, once assembled, snap into place inside the top of the diaper genie.
My Pal Scout needs replacement battery spring..
I would perform a test use of the spring before purchasing it to reach this conclusion. You can call ahead to several part stores that you've identified to carry the spring and request if test use is possible. Then, work with the stores that say "yes". Thank you.
9/30/2022 5:41:42 PM •
Baby Care
Answered
on Sep 30, 2022
Tomy baby monitor srv 400 instruction
Hi
I have Tomy srv 400 but the parent unit is not working. I have attached a photo to show what its giving me when plugged.
If anyone knows how to fix it.
Thank you
4/1/2019 11:49:08 PM •
Baby Care
Answered
on Apr 01, 2019
I feel REALLY down, I Am Never Going To Get A Baby Girl?
Other
people would say, it does not matter what gender your baby will be and
that is a natural reaction but to some, this is a serious concern. Stop
worrying, Gender Selection Clinic
is the solution to your problem if you are really serious about it.
Technology and science have made it possible for people to get pregnant
and to choose the gender of their kids. The embryo gender selection IVF
is being performed by medical doctors around the world. This system has
been proven for decades. The success rate of having a girl is 93%. This
method though is a bit expensive but if you really want it, then the
cost would not be a problem to you. Both you and your husband must have
an open mind on this. Otherwise, it will create misunderstanding between
the two of you.
8/15/2018 7:03:40 AM •
Baby Care
Answered
on Aug 15, 2018
Is it dangerous to wear the wrong size of nursing bras?
Usually a woman's breasts engorge very quickly after giving birth and take a few weeks to gain a stable size, usually one size bigger than what she had before giving birth.Because of the quick and unpredictable extent of ****** growth some women end up wearing the wrong bra size, and while wearing a bigger size may just turn out to be uncomfortable, wearing a smaller bra size while breastfeeding may reduce their milk supply and cause a painful infections called mastitis.
4/3/2018 2:57:56 AM •
Baby Care
Answered
on Apr 03, 2018
How do they work
The basic loop is simple:
Feed
Burp
Change diaper
Get to sleep
Repeat
Then you need to work in a "change clothes" subroutine, which runs once/day, or when the outfit is filthy.
But while that loop is running, you need to frequently:
Maintain eye contact
Smile
Talk (content not important; babies hear high pitches better)
Play (Peek-a-boo works with a wide range of ages, but basically any repetitive action delivered with a smile will amuse a baby)
And snuggling. Lots and lots of snuggling.
10/22/2017 2:46:29 PM •
Baby Care
Answered
on Oct 22, 2017
How can I get a copy of the manual?
Manuals are often available for download from the manufacturer.
Step 1: to find the brand and model of your sterilizer
Step 2: locate the website of that brand on the internet
Step 3: search their product and/or support pages using the model number of your sterilizer.
5/3/2017 5:09:15 PM •
Baby Care
Answered
on May 03, 2017
