20 Most Recent
Nokia Intrigue 7205 Cell Phone Questions & Answers
My phone keeps turning on
Hi,try to my advice if your cellphone automatic turn off and on,you need to delete you message memory or inbox or if want to reset your cellphone.please save your files and contacts before you reset your cellphone.you select the settings-select factory reset-and default password nokia 12345.i hope its work ok, thanks :)
I turn on my Nokia
Hi, when a phone freezes all the time ,it means that memory has been affected by VIRUS.
VIRUS can damage a phone in no time. VIRUS can be caused by downloading applications on your phone through the internet, or might be from data transfer from a phone to another phone.
To remove the VIRUS, you will need to flash the phone memory. Flashing the phone will restore back the phone to it normal state.
You can use this link to see how to flash your phone
Flashing a cell phone will erase carrier data from the memory. Cellular companies can usually do this for a fee. Online buyer sites sell the software kit that will flash a cell phone from home computers.
To flash a phone you will need to rewrite the PRL file by connecting your phone to a computer with the needed equipment. Your best bet is to take your phone to a dealer that flashes phones on a regular basis. For more information
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
After trying the above process and still does not work,that means you will need to replace the phone board of the phone ...It's damaged and it can work properly again.
Take care.
My phone is turning off on its own
there is no simple fix to this problem it is an internal icp fault and needs to be repaired by a service tech in most cases it can not be fixed and the hand peace should have a new mc- board or the whole unit replaced
hope this helps
merry christmas
Phone keeps shutting off and
Most of that problem happens if your battery pack need to be replaced with a new one. So better check your battery first. If this trick still not working, there must be a hardware problem with your phone. Its better to bring it to a repair center to get it fix.
I cant download picture messegas
The reason you cannot download picture messages that have been sent to you or send picture messages is because you have not activated the mms(Multimedia Messaging Services) settings on your phone.
Before you can send or receive picture messages you have to activate your internet settings of your sim service provider.
Then you go to your messages, select the message settings, select multimedia settings, then you select the configuration, then you select the internet service provider of your sim.
After doing this you will be able to send pictures and receive picture messages.
Take care
When using my cell phone in the car with blue
go to the enhancements, change the headset connection profile to outdoor or any profile where your mobile is not in silent mode. Even if it doesn't work, try to change the bluetooth system.
Dropped in toilet
Congratulations!!! remove every parts you can i.e. battery, SIM card and memory card. Make sure each and every single drop of water is out. Wrap the mobile phone thick with a piece of cloth and keep it on a warm place ( Not too warm ) like Above the TV( thats the best i can suggest) for couple of days, 3-4 days will be sufficient. Make sure you don't switch it ON while its wet otherwise the Flash IC might get fried by the battery. After 3-4days of evaporating the water from your Mobile, keep fingers crossed and switch ON the Mobile. If switched ON perfectly for 10-15 minutes (try checking all the feature in this time period) the mobile phone is in good status and if it doesn't kindly purchase a new Phone because i won't suggest you to get it repaired as once Nokia phone goes for a repairing it will always ask for repairing after 2-3 months.
Phone will not stay on. It shuts down, restarts,
This is a KNOWN problem with this phone.
Read all of this answer before deciding what you want to do. You'll have several options:
To correct the problem yourself you'll need to have another (older) phone (not a
7205 Intrigue) that your phone number can temporarly be transferred to. Then, follow these steps:
1. Assign your phone # to a different device using its EIN.
2. Startup the
other phone and make sure all text messages & other undelivered
stuff is picked up by the other phone.
3. Turn the other phone
off, reassign your # to the 7205 Intrigue, and start it up. Problem
solved!
Some key points:
- you can
do this yourself on Verizon online--if you have another operable device
to switch to; otherwise, you can go into a Verizon store and have them
switch to a test phone for you. Obviously, the other phone cannot be a
7205 Intrigue.
- after switching your # to this new device, you
MUST wait SEVERAL MINUTES and confirm that all the msgs floating around
in the system while your Intrigue has been malfunctioning are delivered
to the new phone.
If you switch back and forth too quickly the problem will NOT
be solved.
Nokia is aware of this problem and sent a bulletin on 7/30
stating that the bug will be addressed in the next software release for
this phone (no target date specified.
Intrigue owners will not receive any notification when
this software release is available, and that the phone will have to be brough to Verizon to have them load the update.
Unless you're attached to the Intrigue, exchange your phone for a
different model and avoid this headache! (That is, of course, if you
kept the original packaging which Verizon requires for exchanges of even
faulty, nonfunctional equipment.
Call verizon, and see if the software update has been released.
a. If so, go have it installed on your phone.
b. If not, do the EIN switch. If the
problem happens again, go back to step II.
