20 Most Recent Sony DVP-NS315 DVD Player Questions & Answers
2answers
Only black and white movies
your tv is posibley on svhs instead of av1 or av2
have a look at the logo that comes on when you chose the channel
4/28/2020 5:46:33 AM • Sony DVP-NS315... • Answered on Apr 28, 2020
3answers
Playing movies in black and white
Use a scart lead to connect it to the TV, that should cure it.
4/7/2020 6:34:54 AM • Sony DVP-NS315... • Answered on Apr 07, 2020
2answers
Using DVD player without remote
yes when you get to the dvd menu press play
3/12/2020 3:39:03 AM • Sony DVP-NS315... • Answered on Mar 12, 2020
2answers
Sony DVP-NS315 cant play only Video Disc
If you are using just a "yellow" ended cable for the video, maybe your custom settings are set to use "component"? I have been using this same dvd player for a while with the component video out and it works fine. I hope this helps.
2/20/2020 7:55:51 AM • Sony DVP-NS315... • Answered on Feb 20, 2020
"Cannot play disk"; "Disk is dirty"
Check and replace the laser pickup unit. It is faulty. Weak. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
5/11/2017 5:22:47 PM • Sony DVP-NS315... • Answered on May 11, 2017
0answers
0answers
0answers
Default code for dvp-ns315 parental control
the default code for it may be one of three 1234/0123 or 0000 although the last is least likely
11/3/2013 10:44:56 PM • Sony DVP-NS315... • Answered on Nov 03, 2013
Someone put a code on my box it wont show any
most electronics have a reset or a shop display setting you activate this by disconnecting the power for about three minutes this should bypass the passcode
11/3/2013 10:28:39 PM • Sony DVP-NS315... • Answered on Nov 03, 2013
Dvd tray stuck
there is a pin under the dvd drawer that needs to slide in a slot on the bottom of the drawer. See if it is in the slot correctly.
7/8/2013 2:53:37 PM • Sony DVP-NS315... • Answered on Jul 08, 2013
Instructions for cleaning the lens
For more details type in this site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search or press Enter. It is an electronic equipments service help site.
Note the position of hyphen in between words in site name. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
You can locate this site name, either at the bottom part of first search page, or at the top of second page.
Detailed descriptions are there to help you. Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price and more.
6/6/2012 3:03:29 PM • Sony DVP-NS315... • Answered on Jun 06, 2012
0answers
Unlock a dvd player sony dvp-ns315 for all region
impossible, I have one too but there is no "hack" here
12/31/2010 12:27:08 AM • Sony DVP-NS315... • Answered on Dec 31, 2010
0answers
When I try to eject the DVD that is in the
what you will want to do is go into the users guide and find the reset factory defaults option usually it involves holding a button or two while starting the device however are sometimes very different
hope this helps
Robb
11/7/2010 2:12:52 PM • Sony DVP-NS315... • Answered on Nov 07, 2010
Display says "cannot play"
There is some dust problem first you have to clean the optical block with disc cleaner. If still have problem then need to replaced optical block with new one.
11/4/2010 6:34:41 PM • Sony DVP-NS315... • Answered on Nov 04, 2010
Every time i try to put in a disk, it says its locked
Yes,Some one have set the child lock ON accidently.so it appears as LOCKED
As this child lock is ON you cannot open the tray.
Please follow the below steps to open child lock,
When player is in standby mode press RETURN,ENTER and then ON/STANBY BUTTON again.
You can open it.
If it appears as TRAY LOCKED ,You should contact your sony dealer or authiorised sony service centre.
Thanx
7/26/2010 8:13:45 AM • Sony DVP-NS315... • Answered on Jul 26, 2010
Sony DVP-NS315 DVD Player Logo
48 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
dvd tray stuck
  • Televison & Video
