20 Most Recent
Sony FD Trinitron WEGA KV-27FV310 27" TV Questions & Answers
Sony TV - Loss of half the picture
sarge, it sounds like the vertical output IC went bad on you. If it was a bad connection or a bad capacitor, your picture would have been a straght line across the screen. They call the output section of the IC a push-pull type of amp, so the top half of the sweep IC went out. If you have had some soldering experience, and or experience with solid state repair, locating the bad IC and replacing it is no big deal. If you havent, stay safe and call in a pro to assist you in this repair, as there is alot of high voltage inside this puppy that is still present even if the set is unplugged. It should not cost an arm or a leg to repair this set. An honest repair on a set like this if you take it in should not exced 125 to 150 bucks. Good Luck
PS Please dont forget to rate this thread.
9/22/2013 1:32:40 PM •
Sony FD...
Answered
on Sep 22, 2013
Why does the power switch does not turn on tv?
You likely have a problem in the power supply of the set or in another area.If the power light is on and or blinking count the blinks to see if a sequence or not---If total dead (no power light etc) follow cord for power inside the set to the line fuse that is there.
12/20/2012 3:36:26 PM •
Sony FD...
Answered
on Dec 20, 2012
I will not just turn on normally. I have to press
Hello Juan Elizondo,Welcome, and thank you for using FixYa!To answer your question: This symptom is known as Logic Lock. I would say you don't have exactly the right code programmed into the remote, or the remote is damaged.Unplug your TV and run down to your local TV Repair Center or WalMart to purchase a replacement Universal remote. Plug the television back in and reprogram this remote with your television's code. That should fix your issue.Have a great day!
12/8/2011 5:02:18 PM •
Sony FD...
Answered
on Dec 08, 2011
I have a Sony FD
The set has a vertical deflection problem, the vertical ic and a few capacitors will need to be replaced to restore the tv to normal function.
4/29/2011 1:53:02 AM •
Sony FD...
Answered
on Apr 29, 2011
Tv problems
It's called a loss of vertical deflection. In this particular model your set uses a TDA8172 for a vertical Ic, at board position Ic561.
Replacing that and check or replace the feed cap out in front as needed should restore full deflection. It's not an expensive fix for a qualified shop either.. But my advice is take it into them and save the pu/del charges. And call around to see if they have the Ic on-hand and about how much it will be to replace it before choosing the shop to take it to..
Let me know how it goes!
Bill
1/14/2010 5:49:11 AM •
Sony FD...
Answered
on Jan 14, 2010
The top half of picture is completely back, please
you have a vertical problem it could be a cold solder joint on the vertical out put ic or a component failing in the circuit
if you have the tools a soldering station and some know how you can fix this
or you may want to contact a local for help with it
11/9/2009 1:17:48 PM •
Sony FD...
Answered
on Nov 09, 2009
OUr Tv will not turn on. It also makes a loud bang
DO NOT TURN ON THIS SET.
Take it to a qualified television technician or have a house call made to repair the problem.
The only things which can cause a loud bang from electronics are things you DO NOT want to mess with.
It is most likely a problem with the power supply.
10/6/2009 4:22:58 PM •
Sony FD...
Answered
on Oct 06, 2009
Tv image shifted right
Horizontal hold IC and circuit is failing The remote signal will cause it to spasm because of this faulty set of parts. It needs professional intervention to fix this properly
9/25/2009 6:35:35 AM •
Sony FD...
Answered
on Sep 25, 2009
On a Sony TV the top 4-7 cm of the screen
This is a vertical output failure and/ or capasitor failure in this circuit, the repair would cost around 150 at a shop to fix. I don't want to quote any shop's pricing but it should be around this price. If you want to fix this yourself you will need soldering skills and know he dangers of working inside of a tv. If you are failure with these issues, you are looking for a 5 pin ic attached to a heat sink near the flyback transformer, near this part will be several caps, that need tested or just replaced, I am not at the shop right now so i don't have an exact part number or location for this set, but if you want to attempt this repair let me know and i will get you the part number and location for the parts.
9/3/2009 1:42:29 PM •
Sony FD...
Answered
on Sep 03, 2009
Only bottom half of the screen shows, also i need the service menu. How can i get to it. Thanks in advance!
I'm not familiar with this model of Sony, but the picture shows a CRT TV.
If this is so, your vertical deflection circuit has gone bad (it's nothing to do with the service menu).
This can be caused by bad capacitors in the vertical deflection circuit, a bac IC, bad power supply to the IC, bad solder connections, or a combination of any of the above.
In this case I would use a scope to test the circuit to see where to start from. You can always do a visual inspection to check for blown or burnt parts and bad solder connections. Other wise you'll have to have a sevice person look at it.
6/9/2009 6:19:17 PM •
Sony FD...
Answered
on Jun 09, 2009
Sony KV40XBR800
YOU MAY HAVE A BAD IC 2504 OR M BOARD EST $250.00-450.00
1/12/2009 9:06:55 PM •
Sony FD...
Answered
on Jan 12, 2009
Sony TV Repair
8 BLINKS IS INDICATIVE OF A HV PROBLEM WHICH CAN INCLUDE THE CRTS. MINIMUM REPAIR IS $300.00 TO $1300.0
1/12/2009 9:02:45 PM •
Sony FD...
Answered
on Jan 12, 2009
Sony Tube TV picture
YOU HAVE A VERTICAL DEFLECTION PROBLEM. EITHER SOLDER CONNECTIONS OR THE PUMP UP CAPACITOR.
1/12/2009 8:54:03 PM •
Sony FD...
Answered
on Jan 12, 2009
No picture on half of screen
The vertical output IC is most likely the cause. On a 27 inch TV the generic part number is AN5522 the location number ic IC561. Be careful of dangerous voltages within the TV powered on or off.
1/12/2009 8:52:08 PM •
Sony FD...
Answered
on Jan 12, 2009
SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
10/25/2008 4:36:25 PM •
Sony FD...
Answered
on Oct 25, 2008
Sony KV-27FV310
Component In is not converted to composite out (yellow)
TV monitor out normally goes to A / V receiver in......T.
11/18/2007 5:47:01 PM •
Sony FD...
Answered
on Nov 18, 2007
