20 Most Recent
Sony FWD-50PX1 50 in. HD-Ready Plasma Television Questions & Answers
Sony FWD 50PX1 Plasma Screen
If you check the power supply module , you probably will fine a couple electrolytics caps that will be bulged and need replace and also the low uf caps are normaly bad too, but they will look good. Change out the electrolytic caps, or change out the power supply module. Go to
www.partstore.com to buy a new one.
My tv turns on, I get a crazy looking screen with
Hi:
You problem is due to a failing x-sustain board, this board is mainly responsible for lighting the screen up. It may also be because of a faulty digital board assembly, but since you say the screen goes blank, I will lean more to the X-sustain board about to fail. It is common practice to replace the Y-Sustain board as well when replacing the X-sustain.
Is there anywhere to purchase a HDMI card FWD-50PX1
I don't think they exist, I would try contacting Sony directly first.
Is it imperative you have HDMI? I can recommend an excellent HDMI to component video converter if you are using an HDMI only source.
Cheers,
I have a sony fwd50px1
Here was the solution for the same black line but, in them middle of the screen.
hi there your problem is cause by the low side a ***.y board is faulty.hope this help.
Y board fault.
Board is around $289.00 cost, if you can find one, Most likely if your display turns on and has no picture the display is bad time for a new plasma monitor, and it's a Y-SUS board
I don't think it matters only part of your board is bad.
Here's a site that may be of some more help for you.
goto www.interactiverepair.com
Hope this helps.
FWD-50PX1 wil not power up
If you have prior experience of TV repair and know high voltage risk involve in Plasma TV then you may check below mentioned voltage on given locations to check what supply is not working for further diagnosis.
Save above image to see enlarge view.
Sony tv 50we655
this is an LCD projector tv.
you can fix it, the same way you broke it by realigning the lcd pannels.
good luck.
Rgb inputs dont work
the connection board or your digital board is bad change the connection board first it is cheaper, then if that does not solve the problem change the digital control board, this is the board where your control panel and connection board is connected to....
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
PLASMA 50IN TV
hi there your problem is cause by the low side a ass.y board is faulty.hope this help
tony.
Any assistance will be greatly appreiciated.
Sounds like you need a white balance adjust, call a local service center, you could do it yourself but you will need access to the factory mode, I don't know how to get into the factory mode for that model
No video from rgb inputs
usually this is a bad connection on the system board, cable, etc. If it's not under warranty, I would check the cable first, and try multiple video sources before opening the unit. Worst case scenario is replacing the system board where the connections reside.
