20 Most Recent Fuji FinePix A205 Digital Camera Questions & Answers
2answers
Manual for fuji finepix A205 Digital Camera
You may download a copy of the manual here.
10/20/2012 10:16:02 PM • Fuji FinePix... • Answered on Oct 20, 2012
2answers
A210 zoom error
When you first turn the camera on, grab the lens, pull on it slightly. Turn the camera off and try it again. If it doesn"t work the first time , pull on the lens slightly again. It worked on mine
12/21/2011 7:10:13 AM • Fuji FinePix... • Answered on Dec 21, 2011
I have a Fuji FinePix A 205 camera and replaced
I don't know what manual you're reading but the camera will only record 80 seconds at the lowest resolution. This is a very old camera that still uses the now extinct XD card. If movies really interest you, consider getting a new camera. The new models have literally hundreds of new features that I'm sure you will really like.
8/14/2011 9:43:22 PM • Fuji FinePix... • Answered on Aug 14, 2011
How do I get the date to show and stay on the
You need to set the date using Set Up menu and you must remember to reset it after you change the batteries. Have you done that but still don't get dates on pictures?
8/13/2011 10:03:36 PM • Fuji FinePix... • Answered on Aug 13, 2011
How do I set the
You can't. The A205 is a very basic point and shoot camera with no manual control.
5/5/2011 5:18:19 PM • Fuji FinePix... • Answered on May 05, 2011
The camera is giving a zoom error message. the
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
2/15/2011 1:40:18 PM • Fuji FinePix... • Answered on Feb 15, 2011
My camera only records for 20 seconds, can i fix
I assume you mean videos only record for 20 seconds. Check your card....if it is an SD or SDHC card, it needs to be at least a class 6 or better to keep up with the camera while shooting videos.
1/2/2011 11:49:04 PM • Fuji FinePix... • Answered on Jan 02, 2011
I need the sofware to upload pictures onto my pc
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
11/12/2010 6:26:03 PM • Fuji FinePix... • Answered on Nov 12, 2010
Hi, my camera model is Fuji
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Fuji service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the speedy and free answer I have provided for you and any testimonial which you might wish to add is always welcome!
10/11/2010 8:15:32 AM • Fuji FinePix... • Answered on Oct 11, 2010
Zoom error infinepix A205s
Hello
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
Regards
Andrea
9/30/2010 1:16:56 PM • Fuji FinePix... • Answered on Sep 30, 2010
My finepix A205 digital camera show the zoom error
Hello
Regards
Andrea
9/27/2010 5:04:40 PM • Fuji FinePix... • Answered on Sep 27, 2010
I dropped my camera and it still comes on but it
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Regards
Andrea
8/23/2010 2:45:52 PM • Fuji FinePix... • Answered on Aug 23, 2010
What kind of memory cards does this model use
It uses xD Picture Card.
8/7/2010 9:55:28 PM • Fuji FinePix... • Answered on Aug 07, 2010
I have lost the installation disc for my A205 2.0
Not a problem, just go on to the following website
download the software and run it on the system , you amy also urn it on to the disc for future
http://www.fujifilm.com/support/digital_cameras/software/usb/index.html
Problem solved :)
8/2/2010 12:29:10 AM • Fuji FinePix... • Answered on Aug 02, 2010
MESSAGE SHOWING CARD NOT INTIALIZED
Initialize means to format the card....this will completely erase it.
7/14/2010 9:32:35 PM • Fuji FinePix... • Answered on Jul 14, 2010
Camera is still functional but the lens will not
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
12/18/2009 10:41:32 PM • Fuji FinePix... • Answered on Dec 18, 2009
Camera shows that battery is low even when changed
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
11/30/2009 2:53:14 AM • Fuji FinePix... • Answered on Nov 30, 2009
Fuji FinePix A205 Digital Camera Logo
Popular Tags
56 questions posted
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
camera still functional but lens will
  • Cameras
