20 Most Recent
Philips 32RF82S TV Questions & Answers
Goldstar black screen
If conventional set and not LCD etc No high voltage is most likely--that area provides 20,000 plus volts to picture tube and also voltages for audio.To repair or to replace set?
My t.v. is on and
Good Day!
Please check your TV inside if the CRT tube is having heater or light in tube..
I think you don't have a heater or light on the CRT tube because you don't have a picture..
So you have to do is check the heater supply on the CRT socket it should have 6vac test it using multimeter (range in AC) after that trace the line from the CRT socket going to the secondary of the ply-back when you trace the line there is the resistor connected through please replaced it with the same type,ratings and value.
Thank you and good luck
TV BLACK SCREEN WITH THE POWER ON.
It needs repair.
If the line is vertical, then something is damaged on its horizontal circuit section on the mainboard.
If the line is horizontal, the vertical circuit section is damaged.
have it repaired to a qualified service center or person!
avoid switching it to avoid further damage on other parts!
i have a phillips flatscreen plasma sound works but no picture.What can i do to fix it. is ther a chance that it could be something simple? or is this going to cost me a small fortune to fix.
Philipstv
could be an intermittant connection on the picture tube curcuit board,or a bad picture tube, a bad flyback xformer,or a bad b+ capacitor off the flyback that controls the driver transistors on the crt board. Good Luck
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
