20 Most Recent
Amphion Mediaworks M-270 Portable DVD Player Questions & Answers
I cannot open the part to place the DVD in the
Look for a button on the DVD Player said OPEN.Push that button,will open the lid to place in the DVD disc.Or no button siad OPEN.Look on the lid itself,look for a small **** on the DVD player lid or a bump on the lid.
8/11/2010 12:23:52 AM •
Amphion...
Answered
on Aug 11, 2010
AMW DVD Player
my dvd doesnot play ,power is on screen is ok.but the dvd did not play (no rotation of the disk)
3/1/2010 9:07:21 PM •
Amphion...
Answered
on Mar 01, 2010
Where can I find a
For a replacement remote for your model, click on the blue link www.remotes.com and you will find one there. The original remote is no longer manufactured, but they offer a replacement that is as close as possible to original. The price is $39.95. If you want exact, I'd go this route. If you want something not as pricey, you can always opt for a universal remote and you can purchase those anywhere. Hope this answered your question. Please take a few seconds to rate how helpful this post was for you. Thanks and good luck. billyho1977@FixYa
9/19/2008 2:14:04 PM •
Amphion...
Answered
on Sep 19, 2008
How to remove child lock from BELTEK TV?
general steps:
Get the TV remote control and push the "Menu" button and select "Options".
Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip".
Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button.
Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV.
Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control.
If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps:
Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly.
Switch on your TV: Ensure your TV is turned on.
Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice.
Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted.
Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list.
Bed.-Anl. H2 Version1 (ruwido.com)
2012 troybiilt super pony transmission axel is trying to slide out how to fix it
The axles may have substantial amount of in/out play, 1/4 inch or more. Does the axle in question actually drive the wheel or does it freewheel?It's a typical differential so if you get both wheels off the ground and spin one wheel, the other wheel should rotate in the opposite direction.The axles are retained by the differential assembly (inside transmission) so if the axle is truly falling out, to fix it will require transmission be removed and opened. Probably not an economical repair unless you can DIY or replace with good used unit.
